daking Posted November 3, 2014 Posted November 3, 2014 I put together a few parts to allow 3 hoses vent. Transmission, Transfer-case, and Front Diff. Feed to a distribution block, with a small filter. Mounted high up on the firewall. Image Not Found
87Warrior Posted November 3, 2014 Posted November 3, 2014 I like it. Any reason you didn't tie it into the intake tube right there? I assume you have a filter in the cowl.
daking Posted November 3, 2014 Author Posted November 3, 2014 I thought about connecting to the intake instead of a stand alone filter. I decided its best with a stand alone filter. Connecting to the intake tube would apply a small vacuum to vent hoses. Giving the parts a slight negative air pressure. If there are any small leaks in any part, small amounts of dust or water would be pulled in over time. So, I decided on a dedicated filter.
Incommando Posted November 3, 2014 Posted November 3, 2014 You can get the little white factory breather caps for about $2 each if someone wants options.
