fuel pump sock question
I'm changing out this fuel pump and the sock on the bottom of pump is not super tight on there how tight should it be?
There should be some interference....enough that it won't fall off.
The last one I changed, I had to push and twist it to get it to bottom on the pump.
As I remember, there should be a couple of small barbs in the sock collar that cut into the plastic pump and keep it from sliding back off.
