ALIGNING CA BOLTS
I have herd that a picture is worth a thousand words..... Lets see.
Sometimes just jacking up or letting the entire axle droop gets it done. But when thats not cutting it, this little trick works wonders!!!
Just FYI,
CW
The way I do it, is unbolt front driveshaft...
(make sure vehicle is supported well)
remove the LCA bolts at the frame, and replace the UCA bolts
then when it comes to getting the lowers, have them attatched at the axle end, and use a pry bar, or push with your feet till you can get the rear part in place.
works great, but so does the wrench and bottle jack :D
Hey CW...the pipe wrench and jack idea worked great!! I used it today when installing my adjustable uppers. I had to rotate the axle which was being held by the springs. Worked like a charm. Thanks for the idea and pic!!!!!!!!
Its nice when something usually difficult hard can be made easy!!!
CW
