AeroNautical Posted September 16, 2014 Share Posted September 16, 2014 Working on my buddies MJ today and was baffled at what this was. It looks like cruise control, it has a plunger reaching out to the throttle linkage, but I've never seen a CC on these trucks that look anything like this, they usually have a push rod that wraps around over the valve cover. It's an 89 2.5. There is no control for it in the cab, either. I also thought it could be a sensor that tells where the throttle is, like a TPS, but this box looks a bit complex for just that. Also found this at food lion the other day, had Jeep logos all over it. Pretty cool! Link to comment Share on other sites More sharing options...
shelbyluvv Posted September 16, 2014 Share Posted September 16, 2014 It's a kicker solenoid. Used to bump the idle up for power steering or air conditioning. Link to comment Share on other sites More sharing options...
AeroNautical Posted September 16, 2014 Author Share Posted September 16, 2014 Really?? From the factory this truck has neither, no power steering and not even an idler pulley for a compressor. What else would it need to idle higher for? Link to comment Share on other sites More sharing options...
cruiser54 Posted September 16, 2014 Share Posted September 16, 2014 It's the ISC motor. Idle Speed Controller. They all had them. Link to comment Share on other sites More sharing options...
shelbyluvv Posted September 16, 2014 Share Posted September 16, 2014 I was about to type that also Cruiser. It is basically the IAC of the 2.5 engine. They will bump the idle up slightly when the ac is on or when turning the steering wheel while stopped. Like Cruiser said the all had them. Link to comment Share on other sites More sharing options...
cruiser54 Posted September 16, 2014 Share Posted September 16, 2014 I think it also positioned itself to have the throttle opened for optimal start the next time. Link to comment Share on other sites More sharing options...
AeroNautical Posted September 16, 2014 Author Share Posted September 16, 2014 Cool, I'll let him know. Thanks. He's thinking about putting power steering in it anyway, so it'll be of more use then I guess. Link to comment Share on other sites More sharing options...
Jeep Driver Posted September 16, 2014 Share Posted September 16, 2014 My replacement is for a 84 Caddy as they are not listed for the Comanche anymore. Many GM vehicles used the same idle controller. Link to comment Share on other sites More sharing options...
