over heating problems
Yes^^.
AThanks for your post.
We’re here to help but you must understand that all Jeeps are not the same.
In order for us to give you more accurate advice and help, we must know the following, as applicable, along with detailed information as to the symptoms/problems etc:
Year
Model
Engine
Transmission
Transfer case
I overheated while trying to adjust my programable fans. Thermostat stuck open and made me run to cold, put a new oem thermostat in an going uphills its gets hot. I checked the hose and it seems the tstat is stuck closed. Could be one culprit on yours?
