Radiator leaking
1988 Pioneer 4.0L 5spd. Radiator leaking on battery side,can't tell exactly where its coming from without removing battery,fan  shroud ; are Mopars still available,are they the same as one for a Cherokee,is the aftermarket ones the same or better? Also one time before I posted about the axillary fan,someone replied that a fan from a grand cherokee was better,what year cherokee?
Thanks
The 1997 and up XJs had the 10-blade fan. The connector was different so you will have to splice in your old fan connector. Also these fans draw about five more amps on startup, so you may have to increase the fuse size appropriately.
