Dustin_89sportstruck Posted August 6, 2014 Share Posted August 6, 2014 I have an 1989 Jeep Comanche SporTruck and I went and had new tires put on it yesterday and the tech and Les Schawbs told me i needed to replace my rear axle bearings. I went to the local parts store and asked for the bearings but to my surprise there is more than one rear end. How can I tell which rear end is it? It's all factory original Link to comment Share on other sites More sharing options...
AeroNautical Posted August 6, 2014 Share Posted August 6, 2014 I could say what it might be, but the easiest way to tell is if you snap a picture of your differential cover, it's probably a Dana 35. Edit: Oh yeah, welcome to the forums! Link to comment Share on other sites More sharing options...
Minuit Posted August 6, 2014 Share Posted August 6, 2014 :agree: An '89 SporTruck probably has the Dana 35 but with Jeeps of this era nothing is certain. You'll get the right answer with a picture of the differential cover. Link to comment Share on other sites More sharing options...
Incommando Posted August 6, 2014 Share Posted August 6, 2014 My '88 SporTruck had a factory LSD D44 Link to comment Share on other sites More sharing options...
yxmj Posted August 6, 2014 Share Posted August 6, 2014 Here is a pic that would help....it would not (should not) be the 8.25....will not be the 30.....so it is down to the 35 or the 44......if it is bigger and the cover is really round with no indentations........ then you can have a happy dance. . :MJ 1: . Link to comment Share on other sites More sharing options...
mnkyboy Posted August 6, 2014 Share Posted August 6, 2014 89 could have 3 different axles. There's a D44, D35 non clip, and D35 c clip, they all use different bearings and seals. I see you went to Les Schwab so I'm guessing your in the NW, if your close I could tell you exactly whats in there. Link to comment Share on other sites More sharing options...
