VolsJK Posted August 5, 2014 Share Posted August 5, 2014 So needing some advice on what products I need to get. Plan on fabbing pipe myself, but need some guidance. The exhaust from headers back is absolutely falling apart. 92 shortbed 5 spd 4.0 HO. already have new head and gasket from a 97+ (i think, a friend just started giving me stuff lol) manifold: Cat: Muffler: and CAI while we're at it: I want this setup to be NICE. Even show me a full kit. I'm not coming up with much. Link to comment Share on other sites More sharing options...
88ComancheMitch Posted August 5, 2014 Share Posted August 5, 2014 Buy a apn header, use your current downpipe. Single in dual out. Id take a picture of mine, but it's still ugly. I think it was 99+ out something they went to a 2 piece exhaust manifold. You could use that to do true duals all the way back. But I'm really not sure that a 4.0 is really worth having duals. Unless you're rubbing some forced induction I don't see a cost/benefit to justify it. Link to comment Share on other sites More sharing options...
88ComancheMitch Posted August 5, 2014 Share Posted August 5, 2014 Also, if you're really looking into it, you could do a 99+ intake manifold swap. Requires some knowledge to do. Nothing that can't be find here or other jeep/xj websites. I did it to my 98 motor in my Comanche. Gave me quite a bit more throttle response and butt dyno power. No real mpg yet, but still working on o2 sensors/and a/f ratio gauge. Link to comment Share on other sites More sharing options...
VolsJK Posted August 5, 2014 Author Share Posted August 5, 2014 Also, if you're really looking into it, you could do a 99+ intake manifold swap. Requires some knowledge to do. Nothing that can't be find here or other jeep/xj websites. I did it to my 98 motor in my Comanche. Gave me quite a bit more throttle response and butt dyno power. No real mpg yet, but still working on o2 sensors/and a/f ratio gauge. That's what I ended up getting from my XJ guru friend. Thanks for the info! Just wanted some more input on it besides my buddy. When someone knows every mod for everything possible, it's hard to make a decision lol Link to comment Share on other sites More sharing options...
Jeep Driver Posted August 5, 2014 Share Posted August 5, 2014 Vols....... are you in TN? You'll get away with no cat. I had a shop fab me a nice set up for $180 from the cat flange back......down pipe might have cost me another $30 but mine is good. For $210 it ain't worth fabbing an exhaust. Just find a good shop that will give you what you want. Image Not Found Link to comment Share on other sites More sharing options...
VolsJK Posted August 5, 2014 Author Share Posted August 5, 2014 Vols....... are you in TN? You'll get away with no cat. I had a shop fab me a nice set up for $180 from the cat flange back......down pipe might have cost me another $30 but mine is good. For $210 it ain't worth fabbing an exhaust. Just find a good shop that will give you what you want. Image Not Found I am. I know of a few good shops.... We'll see. Link to comment Share on other sites More sharing options...
1987Comanche Posted August 5, 2014 Share Posted August 5, 2014 It might be worth checking the pull-a-part to see if there are any Comanches. I pulled the complete cat back exhaust from a SWB Renix truck and had to cut, reposition, and lengthen the hangers on the system to make it work. The bends and length were correct for the HO truck. It required some work but I picked up the whole system for $30. Link to comment Share on other sites More sharing options...
VolsJK Posted August 6, 2014 Author Share Posted August 6, 2014 Vols....... are you in TN? You'll get away with no cat. I had a shop fab me a nice set up for $180 from the cat flange back......down pipe might have cost me another $30 but mine is good. For $210 it ain't worth fabbing an exhaust. Just find a good shop that will give you what you want. Image Not Found Off topic, but helpful off topic question... What rear sway bar did you use? Wanting one for the rear as well. looks like a stock front XJ sway bar. But I'm wrong. Link to comment Share on other sites More sharing options...
benjy_26 Posted August 8, 2014 Share Posted August 8, 2014 Just wondering, but what's the reasoning behind a dual exhaust on an inline engine? I've seen more and more vehicles with that kind of set up lately. Link to comment Share on other sites More sharing options...
Incommando Posted August 8, 2014 Share Posted August 8, 2014 Just wondering, but what's the reasoning behind a dual exhaust on an inline engine? I've seen more and more vehicles with that kind of set up lately. Sound. A split manifold with true duals sounds neat to those that like it. I ran a piece of 2.5" pipe off of the cat flange. That runs into a thrush welded turbo muffler and then I used a 2.5" 45* turn down right before the rear axle. I get compliments on it regularly and more than one person has asked if I swapped in a V8 after hearing it at idle. I have less than $50 in it. Link to comment Share on other sites More sharing options...
VolsJK Posted August 8, 2014 Author Share Posted August 8, 2014 Just wondering, but what's the reasoning behind a dual exhaust on an inline engine? I've seen more and more vehicles with that kind of set up lately.Sound. A split manifold with true duals sounds neat to those that like it. I ran a piece of 2.5" pipe off of the cat flange. That runs into a thrush welded turbo muffler and then I used a 2.5" 45* turn down right before the rear axle. I get compliments on it regularly and more than one person has asked if I swapped in a V8 after hearing it at idle. I have less than $50 in it. Sweet. Zack put a thrush welded in it. It's still in great shape, just everything else is falling apart ha. Thanks Link to comment Share on other sites More sharing options...
Incommando Posted August 8, 2014 Share Posted August 8, 2014 So you bought Zack's? Link to comment Share on other sites More sharing options...
VolsJK Posted August 8, 2014 Author Share Posted August 8, 2014 So you bought Zack's? I did I did. Started cutting and grinding on these last night ;) Link to comment Share on other sites More sharing options...
Jeep Driver Posted August 9, 2014 Share Posted August 9, 2014 Just wondering, but what's the reasoning behind a dual exhaust on an inline engine? I've seen more and more vehicles with that kind of set up lately. It has a very nice sound to it. And it no longer sounds like a moped or a V6 wannabe. Link to comment Share on other sites More sharing options...
Jeep Driver Posted August 9, 2014 Share Posted August 9, 2014 Vols....... are you in TN? You'll get away with no cat. I had a shop fab me a nice set up for $180 from the cat flange back......down pipe might have cost me another $30 but mine is good. For $210 it ain't worth fabbing an exhaust. Just find a good shop that will give you what you want. Image Not Found Off topic, but helpful off topic question... What rear sway bar did you use? Wanting one for the rear as well. looks like a stock front XJ sway bar. But I'm wrong. S10 or Blazer, with ZJ rods and XJ brackets. Bar mount to axle is off Blazer but welded on. Now on my 8.25 Image Not Found Link to comment Share on other sites More sharing options...
VolsJK Posted August 9, 2014 Author Share Posted August 9, 2014 Sweet! Thanks Link to comment Share on other sites More sharing options...
