Injector orings
My 88 mj is leaking fuel from/around the injector again :( .
I replaced them 2 months ago because the old injector orings where leaking so I replaced it with a napa oring set and had they had been working flawlessly until today. I Smelled a strong fuel odor and I immediately shut it off and opened the hood and saw that #5 fuel injector was leaking .
So I want to ask you guys What kind of fuel injector orings do you guys recomend ?
I used bearing grease since I didn't have oil on me at the time , but thinks for the input I appreciate it I'll check out the bwd
Not sure, but I don't think bearing grease is appropriate. Vaseline is what I have always seen recommended for injector O-rings.
I use clean motor oil.
Just a warning:
If it isn't the o-rings, be prepared. Carry a fire extinguisher?
Never really understood how an injector that squirts out it's tip, into a manifold full of air, could leak fuel through the o-ring sealing the air in......
Just a warning:
Good point -- especially since the manifold is under vacuum, not pressure.
Just a warning:
Another good point.....
