LarryH88bt Posted July 16, 2014 Posted July 16, 2014 I've got some rock auto options for a new TPS. I wanted to ask if anyone has experience with the different kinds. 4.0 renix auto Airtex, most expensive $50 http://www.rockauto.com/catalog/moreinfo.php?pk=937404&cc=1181584 Standard motor products, fancier, $40 http://www.rockauto.com/catalog/moreinfo.php?pk=41499&cc=1181584 Standard motor products, base, $30 http://www.rockauto.com/catalog/moreinfo.php?pk=951161&cc=1181584 The standard almost implies that it doesn't need to be adjusted, not sure I believe that.
88ComancheMitch Posted July 17, 2014 Posted July 17, 2014 Personally, if you have a junkyard around you, I'd get some from there first. You can probably get 3-5 for $30 or so. That is if you have a good place around you. I'm lucky enough to live within minutes of about 6 "U-Pull" places. Makes finding parts nice :) But if you're unable to do that, I'd consider buying the more expensive one if you plan on keeping the vehicle for long.
LarryH88bt Posted July 17, 2014 Author Posted July 17, 2014 Personally, if you have a junkyard around you, I'd get some from there first. You can probably get 3-5 for $30 or so. That is if you have a good place around you. I'm lucky enough to live within minutes of about 6 "U-Pull" places. Makes finding parts nice :) I wish I did. There is one junkyard within reasonable distance but it is not a u-pull and sometimes they can charge more than for something brand new. It comes in handy occasionally but can be pricey.
cruiser54 Posted July 17, 2014 Posted July 17, 2014 I've got some rock auto options for a new TPS. I wanted to ask if anyone has experience with the different kinds. 4.0 renix auto Airtex, most expensive $50 http://www.rockauto.com/catalog/moreinfo.php?pk=937404&cc=1181584 Standard motor products, fancier, $40 http://www.rockauto.com/catalog/moreinfo.php?pk=41499&cc=1181584 Standard motor products, base, $30 http://www.rockauto.com/catalog/moreinfo.php?pk=951161&cc=1181584 The standard almost implies that it doesn't need to be adjusted, not sure I believe that. They all need to be adjusted on a Renix. Have you tried adjusting yours? Here's how: RENIX TPS ADJUSTMENT Before attempting to adjust your TPS, there are two things that need to be done. 1) Be sure the throttle body has been recently cleaned. It's especially important that the edges of the throttle butterfly are free of any carbon build-up. 2) With the Key OFF, and using the positive (red) lead of your ohmmeter, set on the lowest scale, probe the B terminal of the flat 3 wire connector of the TPS. The letters are embossed on the connector itself. Touch the black lead of your meter to the negative battery post. Wiggle the wiring harness where it parallels the valve cover and also over near the MAP sensor on the firewall. If you see more than 1 ohm of resistance, or fluctuation in your ohms reading, some modifications to the sensor ground harness will be necessary. The harness repair must be performed before proceeding. I can provide an instruction sheet for that if needed. TPS ADJUSTMENT FOR ENGINE ISSUES Both RENIX manual and automatic transmission equipped XJs and MJs have a flat three-wire connector to the TPS which provides data input to the ECU. The three wires in the connector are clearly embossed with the letters A, B, and C. Wire "A" is positive. Wire "B" is ground. DO NOT UNPLUG THE CONNECTORS !! Key ON, measure voltage from "A" positive to "B" ground by back-probing the connectors. Note the voltage reading--this is your REFERENCE voltage. Key ON, back-probe the connector at wires "B" and "C". Measure the voltage. This is your OUTPUT voltage. Your OUTPUT voltage needs to be seventeen percent of your REFERENCE voltage. For example: 4.82 volts X .17=.82 volts. Loosen both T-20 Torx screws attaching the TPS to the throttle body and rotate the TPS until you have achieved your desired output voltage. Tighten the screws carefully while watching to see that your output voltage remains where it is supposed to be. If you can't achieve the correct output voltage, replace the TPS and start over. Sometimes, after adjusting your TPS the way outlined above, you may experience a high idle upon starting. If that happens, shut the engine off and reconnect your probes to B and C. Start the engine and while watching your meter, turn the TPS clockwise until the idle drops to normal and then rotate it back counterclockwise to your desired output voltage. TPS ADJUSTMENT FOR AUTOMATIC TRANSMISSION ISSUES RENIX automatic transmission equipped XJs and MJs have a TPS with two connectors. There is a flat three-wire connector, same as the manual transmission vehicles have, and it is tested the same as outlined above—FOR ALL ENGINE MANAGEMENT RELATED ISSUES. However, the automatic TPS also has a square four-wire connector, clearly embossed with the letters A,B,C, and D. It only uses three wires and provides information to the Transmission Control Module. THIS SQUARE FOUR WIRE CONNECTOR IS USED FOR TRANSMISSION/SHIFTING RELATED ISSUES ONLY. First off, DO NOT UNPLUG THE CONNECTORS !! Key ON, measure voltage between "A" positive and "D" ground by back-probing the connector. Note the voltage. This is your REFERENCE voltage. Back-probe the connector at wires "B" and "D". Measure the voltage. This is your OUTPUT voltage. Your OUTPUT voltage needs to be eighty-three percent of your REFERENCE voltage. For example 4.8 volts X .83=3.98 volts. Adjust the TPS until you have achieved this percentage. If you can't, replace the TPS and start over. So, if you have an automatic equipped XJ your TPS has two sides--one side feeds the ECU, and the other side feeds the TCU. For those with a MANUAL TRANSMISSION--the TPS for the manual transmission XJs is stupid expensive. You can substitute the automatic transmission TPS which is reasonably priced. The square 4 wire connector is just not used. Revised 12-15-2013
LarryH88bt Posted July 18, 2014 Author Posted July 18, 2014 I tried to adjust it a long time ago but never got the right readings. I just did it again this morning and I figured it out. Had a 4.88 reference and a .88 output so I adjusted it to .82. Still have a wavering idle cold but once it warmed up fully it leveled off. Next up is the throttle hesitation (it also bogs when trying to accelerate at speed and then surges) and if I blip the throttle quick it can stall and cut out. EGR? That and a battery because this one only works sometimes. Unless I messed up a ground wire but I did the cruiser tips for the dipstick and the firewall/rear head ground refresh.
cruiser54 Posted July 18, 2014 Posted July 18, 2014 Larry, before you spend any more time or money on other things, please click on my link below and do posts 1 through 5, maybe even 27.
