Jeepjeff859 Posted July 13, 2014 Posted July 13, 2014 so today i took off my valve cover and as i started to undo the bolts next to the throttle body coolant come up from the bolt holes and into the cylinder head, is this normal? also whats a good way to clean the engine of the coolant, i drained the oil as soon as it happen in hopes of taking most of the coolant out
oldseddie Posted July 13, 2014 Posted July 13, 2014 We would need to know a little bit about your jeep. What year and engine are you working on?
nitroxsteve Posted July 13, 2014 Posted July 13, 2014 Did you remove a head bolt? On the 4.0 some of the head bolts are exposed to the coolant not sure if ghats true for the 4cyl or not. Some pictures would help.
Jeepjeff859 Posted July 14, 2014 Author Posted July 14, 2014 No they where the side bolts of the valve cover.
Jeep Driver Posted July 14, 2014 Posted July 14, 2014 No they where the side bolts of the valve cover. Don't know how to help you........... The VC bolts will not allow coolant to flow out of them.......if so.......you got serious problems. If you cannot post pics..........?????????............don't' know what to say............
Jeep Driver Posted July 14, 2014 Posted July 14, 2014 so today i took off my valve cover and as i started to undo the bolts next to the throttle body coolant come up from the bolt holes and into the cylinder head, is this normal? also whats a good way to clean the engine of the coolant, i drained the oil as soon as it happen in hopes of taking most of the coolant out Bold 1.........VC is off......correct? Bold 2........with VC off you started to take out other bolts........so it's not the VC bolts......>>correct? Bold 2.....there are no bolt 'next' to the throttle body, so, you must mean the intake.....correct? The bolts next to the intake are the head bolts......are they big bolt or small bolts? If they are big bolts and they are vertical to the engine block.....you are removing head bolts.
Strokermjcomanche Posted July 14, 2014 Posted July 14, 2014 What size socket did you use to take the valve cover bolt out?
ParadiseMJ Posted July 14, 2014 Posted July 14, 2014 so today i took off my valve cover and as i started to undo the bolts next to the throttle body coolant come up from the bolt holes and into the cylinder head, is this normal? also whats a good way to clean the engine of the coolant, i drained the oil as soon as it happen in hopes of taking most of the coolant out If they are big bolts and they are vertical to the engine block.....you are removing head bolts. ...and even if they are head bolts...unless it's Bolt# 11 there shouldn't be any coolant coming out. Pictures??
