pettus253 Posted July 1, 2014 Share Posted July 1, 2014 So I'm new to the page and novice to say the least about wheeling.... Anyways, I recently traded a set of tires for a running 1991 MJ. It's 2wd and has the 2.5L engine and auto trans. I believe the dana 35 it has now has 4:10 gears. I've come across a pretty good deal ($100) for a Dana 30 and a Chrysler 8.25 with 29 spline shafts already set up for SOA. Both axles have 3.55 gears in them. I'm installing a 4.5" lift and 33x12.5R15 tires. I'm just wondering how it's going to drive with the 3.55 gears with it being a 4 cylinder. I'm not in any hurry to complete the 4x4 coversion so I haven't purchased the transfer case yet, and don't plan on doing so anytime soon. Will the 3.55 gears be okay, or should I upgrade to a different ratio sooner than later? This truck isn't going to be a daily driver by any means. Any information would be greatly appreciated. Link to comment Share on other sites More sharing options...
88whitemanche Posted July 1, 2014 Share Posted July 1, 2014 Saposebly from your engine and trans combo your sapose to have 4.56 gears... I have a 4cyl 5speed with 4.10s with a 4.5" lift and 32s and at times I wish I had more gear.... 3.55s will feel underpowered and a cow offroad... Link to comment Share on other sites More sharing options...
mnkyboy Posted July 1, 2014 Share Posted July 1, 2014 I ran 3.55 with 33s for a few years, it sucked but it went down the road. Mines a stick shift, I couldnt imagine driving like that with an auto. I went to 4.88 and its much better, I'm currently going up in tire size so I'm going to 5.38. Link to comment Share on other sites More sharing options...
mnkyboy Posted July 1, 2014 Share Posted July 1, 2014 I've come across a pretty good deal ($100) for a Dana 30 and a Chrysler 8.25 with 29 spline shafts already set up for SOA. Sounds like stock late model XJ axles, the rear is soa but the perches are in the wrong spot so you will need to move them to fit your MJ. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted July 1, 2014 Share Posted July 1, 2014 Saposebly from your engine and trans combo your sapose to have 4.56 gears... I have a 4cyl 5speed with 4.10s with a 4.5" lift and 32s and at times I wish I had more gear.... 3.55s will feel underpowered and a cow offroad... Sa-what? You're right, but supposedly you knew that Link to comment Share on other sites More sharing options...
pettus253 Posted July 1, 2014 Author Share Posted July 1, 2014 Yeah the axles are from a 99 XJ. What's involved with changing ing the perches? Remove, center, reweld? Link to comment Share on other sites More sharing options...
pettus253 Posted July 1, 2014 Author Share Posted July 1, 2014 And looks like I'll be getting new gears in the future Link to comment Share on other sites More sharing options...
benjy_26 Posted July 1, 2014 Share Posted July 1, 2014 I have 31's and 3.55's in mine with an AX4. It's not HORRIBLE, but I would like some lower gears, if nor for outright speed, then at least for more control while going slow. Link to comment Share on other sites More sharing options...
88whitemanche Posted July 1, 2014 Share Posted July 1, 2014 Saposebly from your engine and trans combo your sapose to have 4.56 gears... I have a 4cyl 5speed with 4.10s with a 4.5" lift and 32s and at times I wish I had more gear.... 3.55s will feel underpowered and a cow offroad... Sa-what? You're right, but supposedly you knew that Oops lol... Link to comment Share on other sites More sharing options...
