350MJ Posted June 6, 2014 Share Posted June 6, 2014 I have a dana 35 rear end right now and i am currently redoing all my brake lines after this past winter the negative 30 days were cold enough to burst my brake line. i figure since I'm going through all this work i might aswell convert my rear brake drums to disk brakes. I know some of the grand cherokees later came with rear disk brakes i just want to know what all do i need to grab from the grand cherokee at a junk yard to convert them I'll end up buying brand new calipers and rotors and pads from the store but i still need all the mounting hardware. any suggestions or advice from anyone who has done this? Link to comment Share on other sites More sharing options...
Timeless Posted June 6, 2014 Share Posted June 6, 2014 Grab parts from a ZJ with a dana 35 if you're set on doing the conversion. DIY: http://www.links4jeeps.com/writeups/d35discconversion/ Link to comment Share on other sites More sharing options...
cruiser54 Posted June 6, 2014 Share Posted June 6, 2014 94 to 98 ZJ. Be sure to get the studs that hole the caliper bracket to the housing. They're longer. And also be aware that you need longer rear axle wheel studs. Another thin is to use a 3/4 " wrench/socket and grab the "guts" out of the donor vehicle's proportioning valve to transplant into yours. Link to comment Share on other sites More sharing options...
randomguy310 Posted June 7, 2014 Share Posted June 7, 2014 hey curious what disk brakes can you use for the 8.25 rear end.. Link to comment Share on other sites More sharing options...
350MJ Posted June 7, 2014 Author Share Posted June 7, 2014 Thanks I'm running a 350 small block for a low budget racer and don't have enough stopping power. Link to comment Share on other sites More sharing options...
cruiser54 Posted June 7, 2014 Share Posted June 7, 2014 On 6/7/2014 at 2:41 AM, randomguy310 said: hey curious what disk brakes can you use for the 8.25 rear end.. Same. Just have to grind out the big hole in the caliper brackets. Easy. Link to comment Share on other sites More sharing options...
ScottJeep Posted June 8, 2014 Share Posted June 8, 2014 hey curious what disk brakes can you use for the 8.25 rear end.. http://www.jeepforum.com/forum/f11/fitting-kj-liberty-rear-disc-brakes-xj-cherokee-8-25-axle-750112/ I believe ( not an expert just a good Googler) you will find 05' Jeep Liberty disc are pretty easy to swap into the 8.25 Link to comment Share on other sites More sharing options...
Incommando Posted June 8, 2014 Share Posted June 8, 2014 The best thing that you can do is a dual-diaphragm booster upgrade. Link to comment Share on other sites More sharing options...
Incommando Posted June 8, 2014 Share Posted June 8, 2014 On 6/8/2014 at 12:23 AM, ScottJeep said: hey curious what disk brakes can you use for the 8.25 rear end.. http://www.jeepforum.com/forum/f11/fitting-kj-liberty-rear-disc-brakes-xj-cherokee-8-25-axle-750112/ I believe ( not an expert just a good Googler) you will find 05' Jeep Liberty disc are pretty easy to swap into the 8.25 '02-'07 KJ is a bolt-on...at least to the '98 XJ I saw them bolted-on....You have to use the longer KJ rear wheel studs though. Not sure about '08-up KJ. Starting in '03 rear discs were standard. Link to comment Share on other sites More sharing options...
cruiser54 Posted June 8, 2014 Share Posted June 8, 2014 Booster is a great upgrade. Discs? Here: http://www.cherokeeforum.com/f51/rear-zj-disc-brakes-cherokee-xj-chrysler-8-25-a-57807/ Link to comment Share on other sites More sharing options...
