Dash Cluster Transfer
You need a cluster from a renix jeep 87-90 that has the cable driven speedo ,
91 and up is electronic .
Also you need too get a cluster from a cherokee/comanche with the same engine and you need to swap the water temp sender and the the oil pressure sender which is pretty easy :) .
