Renix Cps Bolt Specs.
Sorry if this is already out there. I did a few quick google and forum searches and haven't come up with anything. A previous owner of my MJ removed the plug for the CPS and used a 1/4 nut and bolt to install a CPS.
I'm in the process of installing a new one and am looking for the correct bolts. What thread and pitch do they need to be? I saw some where that they may have been special shoulder bolts. Is this correct? If so can common bolts be used?
Correct, and take a 11mm socket.
Hit a JY.
These are still available from the dealer. Part number 6503520 'bout $3.50/ea. M7x1.00x25 hex bolt.
Washer?
You mean I didn't need to climb a ladder 10 feet to the attic of my garage, measure said spare CPS bolts? Dang.
I got the new CPS and plug wired in yesterday. Now to reinstall the O2 sensor connector along with a new sensor and a new knock sensor. Some people should not be allowed to work on vehicles, especially wiring!
Progress. Why are you replacing the knock sensor? End pulled off?
