Wow basically no rust, if complete that would go for good money here, too bad it's in the junkyard, boo.
No surprise the Comanche specific parts are gone already - tailgate, tail lights, rear fender flares, cab vents.
I was hoping it still had the tail lights as I need one, but I think I am just going to make my own housing and use aftermarket lights. and all the xj's had no front facia's which I need.
  • 5 years later...
*X2 TRIM STYLE X2 - VINYL BENCH
-YY
135 Zone 35-Washington
1AA U.S. Dealer Retail
4HA Special Scheduling Condition I
ALA SE Decor Group
APA Monotone Paint
BAQ 61 AMP ALTERNATOR
BCX Nickel Metal Hydride Battery
BGA Power Front Disc/Rear Drum Brakes
CBA Straight Back Bench Seat
CKJ Black Vinyl Floor Covering
CSR Passenger Assist Handles
CUM Mini Floor Console
DBB All Manual Transmissions
DDQ 5-Speed Manual Transmission
DHN Command-Trac Part Time 4WD System
DJH 230MM Front Axle
DMF 4.10 Rear Axle Ratio
DRJ 175MM Rear Axle
EPD ENGINE - 2.5L I4 TBI GAS
GAC Tinted Glass Windows
GBB Tinted Windshield Glass
GCB Front Door Tinted Glass
GEC Front Left Side Sliding Window
GNA Rear View Day/Night Mirror
GRZ Left Remote Mirror
GSZ Right Remote Control Mirror
GTZ Manual Remote Mirrors
HCD Do Not Use - See HCA
JAZ DO NOT USE - See JP, KA classes
JCA 85 MPH Primary Speedometer
K3Z STRIPE/BADGE/MOLDING/COLOR
KDD
LAP Shift Indicator Warning Lamp
LBC Glove Box Lamp
LMA Halogen Headlamps
MB1 Black Front Bumper
MBJ Black Powder Coated Front Bumper
MDA Front License Plate Bracket
MFF Black Grille
MHB Bright Windshield Moldings
MMC Rear Door Solid Window Insert
MMG Belt Moldings
MMJ DRIP TROUGH MOLDINGS - TYPE I
NAA Federal Emissions
NBK EVAP Control System
NF2 18.5 Gallon Fuel Tank
PY3 Classic Yellow Clear Coat
QY3 Classic Yellow Clear Coat
RA8 Delete Radio
SBA Power Rack and Pinion Steering
SCB Perforated Steering Whl w/Red Stitch
SFA Standard Duty Shock Absorbers
SGA Rear Shock Absorbers
TAA All Tires
TBC Compact Spare Tire
TBM Tire Carrier Winch
TNC P195/65R15 BSW AS Touring Tires
WJK 15X6.0 Styled Steel Wheels
WLY All Steel Wheels
WMC Bright Wheel Trim Rings
XBS Pickup Box
YAA Build To U.S. Mkt. Specifications
YGE 5 Additional Gallons of Gas
Z01 Rear Spring Group I
Z5A GVW/Payload Rating
Z63 Left Front Spring Group XII
Z82 Right Front Spring Group XI
Body Model JL61
Build date 5/22/90
  • 1 year later...
