1989 Comanche Lynchburg Va. Help.
Ok guys I know it's been a while I had mechanical issues and I was waiting for parts... Now I know most of you hate rustys but my friend works for them and got me good deals.
I got a 4.5 " lift kit
Adjustable track bar
Adjustable control arms and
Single stearinh stablizer
All to be installed this weekend the reason, (any info on things I might run into with this lift while installing would be awesome). I didn't go SOA because I'm not looking to offroad to much and I didn't need that high of a lift.
After the installation with pics this weekend I will be on the look out for front winch bumper and possibly fender flares any ideas on with of those?
There are a couple of different winch bumpers out there. I just built a JCR weld it yourself bumper and it turned out well. They also have the same bumper which they have already welded for you. It is made of 3/16th steel plate and it wraps around the fender to give better protection. You will have to trim the fender a little bit but that's not hard at all.
You can check out my build Green Monster to see what mine looks like. I added the hoops myself but JCR will sell you a kit for it if you want.
As far as fender flares goes I am still trying to decide which ones I want.
Good luck,
Ron
Before
old 3" rustys lift that was already on it
shocks gone
no coil springs
old compared to new
stupid person before me weld
new springs and shocks
rustys extension backet
after
before
after
done so far
front shocks
coil springs
adjustable trac bar
adjustable control arms
steering stabalizer
extension sway bar brackets
brake extension brackets
problems I ran into
I can't get drivers side shock screwed all the way in it won't tighten anymore also won't losen so thats a problem, also bolts that go through control arms wouldnt fit through new control arms had to go find 9/16ths bolt to fit through, and for the life of me I can't get the track bar pin in through the bolt. other then that everything went ok now for the rear only problem with that is I put the new leaf spring packs up to the old ones and it doesnt look long enough hopefully they will fit when I pull the old ones off.
  • 1 year later...
  • 1 year later...
