Exhaust Leak
i have an exhaust leak coming from the flange between the manifold and the downpipe.  the original bolts were destroyed, so i replaced them with some bolts that thread into the manifold, and some springs.  should the bolts have springs or should it be bolted directly to the manifold.  if i understand correctly, they changed from there being a gasket there, to there not being a gasket there.  mine doesnt have a gasket.  should they be spring bolts or just regular bolts?
