92tanMJ Posted February 22, 2014 Share Posted February 22, 2014 I honestly don't know, but I guess... if you're lifting it 4" then it would need to be 4" longer. Eagle? Opinion? Link to comment Share on other sites More sharing options...
Lee21490 Posted February 22, 2014 Share Posted February 22, 2014 I honestly don't know, but I guess... if you're lifting it 4" then it would need to be 4" longer. Eagle? Opinion? Since the driveshaft is at an angle, It actually doesnt take much for 4-5" of lift. When i SOA'd mine, It only pulled about an inch maybe 1.25 inches out of the trans. You should be able to SOA with a stock driveshaft/SY with a longbed. Link to comment Share on other sites More sharing options...
Blaine Posted February 22, 2014 Author Share Posted February 22, 2014 alrighty, thanks a bunch, would you recommend the high angle 1310 u joints and are these available at any part store or is it online? Link to comment Share on other sites More sharing options...
Blaine Posted February 24, 2014 Author Share Posted February 24, 2014 any recommendations for the question above? Link to comment Share on other sites More sharing options...
shelbyluvv Posted February 24, 2014 Share Posted February 24, 2014 No, stock joints are fine. You are seriously over thinking this. Do the SOA and set the pinion in line with the t-case. You will not need a longer SY. You have a long bed and it will be happy with the driveline angles. Start researching shock mounts now. That is a whole new ball of wax on a MJ. Link to comment Share on other sites More sharing options...
Blaine Posted February 25, 2014 Author Share Posted February 25, 2014 http://comancheclub.com/topic/35519-55-600-mj-lift-cheap-high-quality-100-complete-lift/ Here's the list i went with, When i lifted mine. i suppose i don't need a drop pitman arm seeing its not mentioned Link to comment Share on other sites More sharing options...
Lee21490 Posted February 25, 2014 Share Posted February 25, 2014 http://comancheclub.com/topic/35519-55-600-mj-lift-cheap-high-quality-100-complete-lift/ Here's the list i went with, When i lifted mine. i suppose i don't need a drop pitman arm seeing its not mentioned Naw, Works fine without it. Link to comment Share on other sites More sharing options...
mvusse Posted March 1, 2014 Share Posted March 1, 2014 Drop pitman arm will actually worsen the angle difference between the drag link and the track bar, causing bump steer. To prevent bump steer you'll need a "rise" pitman arm, or a drop trackbar bracket. Link to comment Share on other sites More sharing options...
Blaine Posted June 15, 2014 Author Share Posted June 15, 2014 EDIT Link to comment Share on other sites More sharing options...
