54bobby Posted February 6, 2014 Posted February 6, 2014 guys, I started the truck for the first time in a week today and the oil pressure gauge is acting up. hovers around zero, then up to its normal 45 or 50 then will drop down again. was operating fine when parked last week. I did crack the valve cover last week and had some oil blow out. it coated the fire wall and all workings by the trans dip stick. where is the oil pressure switch? or what else could be doing this.
Jeep Driver Posted February 6, 2014 Posted February 6, 2014 Check the connection to the sender. Also, clean your grounds.
Jeep Driver Posted February 6, 2014 Posted February 6, 2014 To the right of the distributor on the side of the block......you'll see a single wire running to the top of it.
onlyinajeep726 Posted February 6, 2014 Posted February 6, 2014 It's the same sender for 4.0 or 2.5. He said he had a gauge and it was going back and forth from 0 to 45-50, so that rules out the idiot light cluster.
54bobby Posted February 6, 2014 Author Posted February 6, 2014 that's right, I have a 2.5. shoot, the beers are kicking in. lol
HOrnbrod Posted February 6, 2014 Posted February 6, 2014 He's got a 2.5 How do you know? I don't see it. 54bobby (and others), why don't you edit your signature to let people know what you drive.
Jeep Driver Posted February 6, 2014 Posted February 6, 2014 He's got a 2.5 How do you know? I don't see it. 54bobby (and others), why don't you edit your signature to let people know what you drive. Because I pay attention.
54bobby Posted February 6, 2014 Author Posted February 6, 2014 that's right, he pays attention and after all, he is an MJ JUNKIE
onlyinajeep726 Posted February 6, 2014 Posted February 6, 2014 You have a 2.5 with an AW4? Isn't that a super rare drivetrain from the factory or have I been misinformed?
54bobby Posted February 6, 2014 Author Posted February 6, 2014 I believe it is super rare but I do believe that's what it is. after all, it is a larado, but to be sure, how can I tell?
HOrnbrod Posted February 6, 2014 Posted February 6, 2014 that's right, he pays attention and after all, he is an MJ JUNKIE :clapping:
54bobby Posted February 6, 2014 Author Posted February 6, 2014 as per obsessive Comanche disorder in one of my older threads, I do have an Aw4.
onlyinajeep726 Posted February 6, 2014 Posted February 6, 2014 That's awesome! I love rare stuff on our rare trucks.
