86 Comanche 4Wd Problem
Okay I have a 1986 jeep comanche and the 4wd is always on, I replaced the actuator and the housing and the light is still on and the 4wd does not work at all, any suggestions?
The lights on but is it really always in 4WD? It would buck like crazy turning corners if it were.
If you do the CAD fix, the light won't work at all. So if you absolutely feel you need that light to know you are in 4WD, you need to find the vac issue. Like cruiser, I have done the fix to every CAD axle since that one in the write-up and just don't care about the light.
Yep. A simple glance toward the console will show the lever position. We don't need no stinkin' lights!!
Yes, perfectly. The CAD system on the front axle was a feeble attempt to increase the fuel mileage on the XJs. Didn't work for that and had it's own set of issues. Factory eliminated it in about 1991. There is NO downside to doing the mod, except the light. And, I have a sneaking suspicion you are of above average intelligence and are perfectly capable of using the lever as in indicator in the light's absence.
