Scottracer Posted January 24, 2014 Share Posted January 24, 2014 Hello, I was wondering if a Dana 60 Rear from a J10 pickup will work in a MJ? I am thinking there would need to be some level of modifications but just not sure how much. Are they all pretty much universal? Length depending I guess which can be fixed but I would consider that more of a major modification. Thanks for your help. Link to comment Share on other sites More sharing options...
Jeepman Posted January 24, 2014 Share Posted January 24, 2014 Anything can be made to fit if you really want it to but I am not sure the width of it but I think it will be really Wide compared to your front axle... There are easier swaps to do that have easier solutions for the front axle... Is this for a DD or weekend warrior? Link to comment Share on other sites More sharing options...
yxmj Posted January 24, 2014 Share Posted January 24, 2014 3rd or 4th post down..... http://bentframe4x4.proboards.com/index.cgi?board=jeeptech&action=display&thread=132 Link to comment Share on other sites More sharing options...
carnuck Posted January 26, 2014 Share Posted January 26, 2014 J10s have Model 20 or Dana 44 rear. Not Dana 60. J20 has full float 8 lug D60 and 71-73 J4000 came with single bearing D60s with 5 on 5.5" pattern (like CJ) Link to comment Share on other sites More sharing options...
Incommando Posted January 27, 2014 Share Posted January 27, 2014 The width of the J10/J120/Wide-track Cherokee axles was about 5" +/- wider than an MJ. The narrow-track Cherokee and Wagoneer are closer to a match in width at about 60" +/-. The rear swap is as easy as cutting off the perches and welding new ones in the correct place and adding shock mounts where needed but that would leave you with either a 6x5.5 lug pattern on a D44 or M23 or 8x6.5 pattern on the D60 (ignoring the early D60's and D44's as they are significantly weaker than the later versions. ) As the MJ has a 5x4.5 lug pattern and I know of no adapter to make them match nor an easily/cheaply adapted 6x5.5 or 8x6.5 matching front axle that would be a deal breaker for me. The FSJ corporate axle was actually the Model 23 to differentiate it from the trouble-plagued model 20. I have not been able to get anyone to confirm if the MJ had the 2-piece axle shaft M20 like the CJ or the stronger 1-piece axle shafted M23. It is easy to tell the difference by the flat hub center on the one-piece M23 and the spindle protruding on an unconverted M20. Link to comment Share on other sites More sharing options...
a4xnut Posted January 27, 2014 Share Posted January 27, 2014 The Model 20 found in select 86 MJ "Metric Ton" rigs has one piece axles and heavier duty housing like the FSJ variant, not the weaker CJ 2-piece style with the weker axle tubes. Link to comment Share on other sites More sharing options...
carnuck Posted February 12, 2014 Share Posted February 12, 2014 Yup. The MJ Model 20 tubes are thicker steel. Link to comment Share on other sites More sharing options...
Incommando Posted February 12, 2014 Share Posted February 12, 2014 Cool. Internally those were known as the Model 23 and they are a dandy axle. They fix all that is wrong with the Model 20 and the center section is a stout one inside and out. They used those diffs in Humvees and H1's but adapted them to IRS/IFS. Link to comment Share on other sites More sharing options...
carnuck Posted February 13, 2014 Share Posted February 13, 2014 They gained clearance with the hub reduction drives. Link to comment Share on other sites More sharing options...
