54bobby Posted January 10, 2014 Share Posted January 10, 2014 guys, I wana put new mounts on the engine and trans. truck is a 87 2.5 4x4 with an AW4. I found what seem to be a quality engine and trans mount in the anchor company from rock auto. can you guys please chime in on wether or not the anchor mounts are a quality product. Link to comment Share on other sites More sharing options...
buffalob Posted January 10, 2014 Share Posted January 10, 2014 I am running the "bomb proof" motor mounts from M.O.R.E. (mountain off road ent) on my 88' 4 liter. (pricey but nice). I know the offer mounts for the 2.5 also...not sure about the trans mount though. Link to comment Share on other sites More sharing options...
88whitemanche Posted January 10, 2014 Share Posted January 10, 2014 I ran with the brown dog motor mounts for a week because I couldn't stand the vibration through the cab so I just went with the cheap $10 motor mounts.... Brown dog mm-They are stout and throttle response with them was awesome because it felt sturdy but the vibes sucked!!!! I have the 2.5 and thought if I was in the trail and my motor mount broke the $10 one would be easier to accommodate than the pricey ones I know your asking more of the quality brand...hopes this helps Link to comment Share on other sites More sharing options...
nitroxsteve Posted January 10, 2014 Share Posted January 10, 2014 I have "anchor" motor mounts in my truck never used the trans mount. Its a 4.0 not 2.5 not sure if that makes any difference or not. My mounts came from advanced and have done a good job for the last two years. They looked exactly like the stock mounts. Link to comment Share on other sites More sharing options...
54bobby Posted January 10, 2014 Author Share Posted January 10, 2014 from what I've read, the engine mount replacement is pretty simple. put truck on stands, jack up engine from oil pan using a block of wood, the remove and replace. is this proper procedure? is the trans mount procedure basically the same? any tricks or things to watch out for while doing these? Link to comment Share on other sites More sharing options...
nitroxsteve Posted January 10, 2014 Share Posted January 10, 2014 yep it easy just don't get carried away with the jack and crunch your oil pan. trans mount is the same just use a Jack to get the weight off the mount. Link to comment Share on other sites More sharing options...
carnuck Posted January 11, 2014 Share Posted January 11, 2014 If you have a fan shroud, be careful it doesn't get crunched. Link to comment Share on other sites More sharing options...
54bobby Posted January 11, 2014 Author Share Posted January 11, 2014 do I have to jack the motor up that far that the fan will break the shroud? Link to comment Share on other sites More sharing options...
nitroxsteve Posted January 11, 2014 Share Posted January 11, 2014 I found out I had broken motor mounts when I accelerated hard one day and the fan hit the shroud. I had not replaced the shroud before I installed the new mounts so I don't know how close you will get to it but you definitely need to keep any eye on it. Good advice from carnuck. Link to comment Share on other sites More sharing options...
54bobby Posted January 11, 2014 Author Share Posted January 11, 2014 I thought he ment watch out for the shroud while jacking up the engine. Link to comment Share on other sites More sharing options...
88whitemanche Posted January 11, 2014 Share Posted January 11, 2014 You don't have to jack the truck that far up to get the mounts in...just enough that the thread come out of the holes...I did both motor mounts in 45 min my first time no help..... Link to comment Share on other sites More sharing options...
