87Warrior Posted January 1, 2014 Share Posted January 1, 2014 For those who have done the 97+ conversion, these questions are for you. It has been a LONG time (about 3 years) since I tore down the donor XJ and am having some memory issues..... Is there a gasket that fits between the brake pedal bracket and firewall where the booster bolts come into the cab? I am working on getting my truck put together and can't quite remember if there is a gasket or if the pedal bracket contacts the firewall. Link to comment Share on other sites More sharing options...
Alexia Posted January 1, 2014 Share Posted January 1, 2014 I have seen white foam gasket of some sort that goes there. Mine did not have one when I installed it. On pictures I have seen it in it looked more for insulation purposes than sealing. Link to comment Share on other sites More sharing options...
87Warrior Posted January 1, 2014 Author Share Posted January 1, 2014 Thanks :thumbsup: I do have a white foam gasket that fits between the firewall and the booster. It just been so long since I took the XJ apart that I couldn't recall if there was as gasket on the inside and my record pictures were no help. Sounds like I haven't misplaced anything...yet :rotfl2: Link to comment Share on other sites More sharing options...
Akula69 Posted January 1, 2014 Share Posted January 1, 2014 Not on the inside, but I sealed around the bolt entry locations anyway...just to ensure a good seal. Alexia is correct - the booster does have a whitish foam gasket on the engine bay side. Link to comment Share on other sites More sharing options...
COFFMAN Posted January 1, 2014 Share Posted January 1, 2014 Correct, as I bolted mine in yesterday . Deep reach sockets are also handy Link to comment Share on other sites More sharing options...
87Warrior Posted January 6, 2014 Author Share Posted January 6, 2014 Question number 2: In the below photo you will notice the front two plugs on the PCM are empty. I am trying to recall what piece, or pieces, of harness plug into these empty spots. Are both plugs for these empty spots part of the engine block harness? Since my engine and engine harness are a 40 minute drive from my house, I am unable to simply, 'take a peak'. Any my curiosity is driving me nuts :dunno: Thanks again :) Link to comment Share on other sites More sharing options...
Alexia Posted January 6, 2014 Share Posted January 6, 2014 Yes, they are part of the engine wiring harness. Link to comment Share on other sites More sharing options...
shelbyluvv Posted January 6, 2014 Share Posted January 6, 2014 Yep, engine harness Link to comment Share on other sites More sharing options...
