87MJproject Posted December 16, 2013 Share Posted December 16, 2013 Hey guys i just bought my 2nd MJ on thursday. it was in pretty rough shape. but I'm planning on getting it back to the beauty she should me. i just got a few questions it needs a new steering column and doors and driver fender. i was wondering if i can get it all donated from an XJ around the same year. from what i can find i don't see why not and if any of you have done it before that would be great to hear some advice on the steering column. Thanks Brady Link to comment Share on other sites More sharing options...
gogmorgo Posted December 16, 2013 Share Posted December 16, 2013 I've never swapped a column myself, but I have recently somewhat disassembled one. All the parts you mention are the same on the XJ and MJ. Also remember you want the doors off a 4-door XJ. Edit:: Ignore anything I may have said before about removing the column. Guess you don't need to disassemble it before removal. Link to comment Share on other sites More sharing options...
AMCJeepMJ Posted December 16, 2013 Share Posted December 16, 2013 When looking for a donor XJ for your 87, make sure the column is a 87-89, as 1990 has a little bit setup on the behind-the-dash parts on the top of the column which can cause confusion during installation. Should you look for a tilt column, make sure it does not wobble up/down or side/side. if it does in even the slightest, move on to the next vehicle in the salvage yard. To remove a column, first disconnect battery, then remove the steering shaft bolt from gearbox, remove the bolts where column goes through firewall, remove the 2 nuts under the dash, undo electrical and cruise connectors, and then remove column from vehicle. Assembly is reverse of removal. Have a 2nd person on hand to reconnect the steering shaft while the other maneuvers the column. Changing a column is easy and a first-timer can get it done in under 2 hours. Good luck. Link to comment Share on other sites More sharing options...
