partsmj Posted April 16, 2007 Share Posted April 16, 2007 I did the google and found this on the internets. http://www.rocky-road.com/comanche.html Is anyone familiar with this kit? It sounds easy to do, and the price seems reasonable. Link to comment Share on other sites More sharing options...
cocco78 Posted April 16, 2007 Share Posted April 16, 2007 All you need to SOA the rear is a few inches of 2" square tube. I cut a couple pieces about 8" long, drilled a hole in the top for the spring center pin, and then just ground out a half circle... I tacked them to the axle tube parallel with the original mounts with my 110v, brought the axle down to a truck repair place and they burned them on for $15... For the shocks I welded some grade 8 bolts to the axle tube, works pretty damn good for now. For the front we just pieced together some 4.5" coils, an adj trac bar, adj lower control arms, some cheap shocks, and extended brake lines.. Cut some fenders and for $300-$400 you can spend the money you save on big tires! LOL, this truck was built on a $1000 budget, including the price of the truck. I think we had a pretty decent wheeler for the price. I believe we have about $1500 total into by now. Link to comment Share on other sites More sharing options...
Tracker Posted April 16, 2007 Share Posted April 16, 2007 I've done this kit twice because the first truck was wrecked. Short answer: I like. More detail: see the current thread in The Pub about lifts. Link to comment Share on other sites More sharing options...
Pete M Posted April 16, 2007 Share Posted April 16, 2007 2 thoughts: -Mopar leaf perches are like $10 for a pair and super beefy. -If you're going SOA, you probably are adding tires that are too big for a Dana 35. The bolt-on concept is unique and clever, but it my view it just isn't worth while when all you need is to find a friend or business with a welder. Link to comment Share on other sites More sharing options...
DirtyComanche Posted April 16, 2007 Share Posted April 16, 2007 There's kits the use a similar concept to convert FS trucks to link rear suspension. Personally I think it's kinda hack. And as Pete said, if you're SOA you're gonna have too much tire for the D35. Link to comment Share on other sites More sharing options...
feerocknok Posted April 16, 2007 Share Posted April 16, 2007 I think it's a neat concept, but I weld things that sometimes only need bolts anyways, so I say weld it. I got the Mopar perches for $12. They're wonderful! Link to comment Share on other sites More sharing options...
comanchedude Posted April 17, 2007 Share Posted April 17, 2007 I have these units I bought them 2 years ago to do my SOA My thought was they are long 7" long and would support the springs better and should reduce/control spring wrap, also I can re-use when I upgraded my axel And at the time I did look at the stock type and they are just too small/short for the SOA (my opinion) so I like to try cool stuff and these looked cool so I bought them used them on the 35 until recently I bought a factory MJ AMC20 axel and re-used the brackets ,had to grind on them a bit for clearance as the 20 tubes are a bit larger This time I did weld them on as I don’t think I will need to change axels again. Besides that they don’t lock into the AMC20 saddles So if you don’t have a welder or don’t want to fab up your own, these are very well made and will help reduce spring wrap due to there length and they are very simple to install they actually lock into the D35 perch to provide a solid non welded system. And you can re-use them when you do upgrade your axel (with some grinding for tube size) Her are some pics,it was dark so I had to “brighten” them so if they look bad ,sorry Link to comment Share on other sites More sharing options...
