I have an empty plug under the air box on my '87 Comanche.  It's a 2 pin just like the MAT sensor MALE with a green waterproof rubber grommet.  Does anyone know what this is supposed to plug into?
Photobucket is not working for me today, neither is Picasa :fs1:
  It looks like this except with two pins.  I thought I knew at one time but now I forgot.
mopar-crnksft-position-sensor-33004761-a
It plugs into the temperature switch in the radiator that turns on the electric fan when the coolant gets too hot.
It plugs into this thing:
The above fan switch screws into this opening:
That explains why I have that plug as well. My truck came without an auxiliary fan from the factory, I have since added one with a home made controller run off a sensor in a HO thermostat housing.
