relyt120 Posted November 9, 2013 Share Posted November 9, 2013 Does anyone know if i can use Felpro : ES71102 in my 89 auto 2wd 4.0l MJ? They are listed for 96-01 XJ but I cannot find any listed for renix XJ/MJ locally and I need them this weekend. Opinions appreciated. Link to comment Share on other sites More sharing options...
jimoshel Posted November 9, 2013 Share Posted November 9, 2013 I have a 1987, 1989,1996 and a 1998 4.0 engines sitting side by side. Just looking at them I can not see any difference between the head bolts.For what it's worth. Link to comment Share on other sites More sharing options...
relyt120 Posted November 9, 2013 Author Share Posted November 9, 2013 Thanks Jim, I thought they would be the same but the computer insists they are different. I went ahead and picked up a set and will attempt to use them when I change my head gasket tomorrow. Time will tell if they are the same. :thumbsup: Link to comment Share on other sites More sharing options...
Alexia Posted November 9, 2013 Share Posted November 9, 2013 See those two studs sticking out of the smaller bolts in the bottom of the Fel-Pro product picture? Those are locator pins for the newer style valve cover gasket. Those bolts go in holes #8 and #9. At worst you buy the newer style valve gasket if the replacement does not have the holes. Head bolt sticking up at hole #8. Can see in the back where the gasket slips over it at hole #9. Link to comment Share on other sites More sharing options...
relyt120 Posted November 9, 2013 Author Share Posted November 9, 2013 I failed to mention that I have a newer style valve cover so it has the newer gasket. I will reuse it since its less than a year old and also is a nice felpro one. Link to comment Share on other sites More sharing options...
Alexia Posted November 10, 2013 Share Posted November 10, 2013 I failed to mention that I have a newer style valve cover so it has the newer gasket. I will reuse it since its less than a year old and also is a nice felpro one.You are fine then. :D Link to comment Share on other sites More sharing options...
carnuck Posted November 10, 2013 Share Posted November 10, 2013 The difference is the newer headbolts are torque to yield (ie: Not for re-use) Link to comment Share on other sites More sharing options...
HOrnbrod Posted November 10, 2013 Share Posted November 10, 2013 The difference is the newer headbolts are torque to yield (ie: Not for re-use) Are you saying "newer" 4.0L engines used TTY head bolts? What's your definition of "newer"? Link to comment Share on other sites More sharing options...
carnuck Posted November 20, 2013 Share Posted November 20, 2013 According to Felpro the change was in '97 Link to comment Share on other sites More sharing options...
