8.8 axle weld?
nooooo you can't do that. its not that hard to pull the axles once you take the cover off, BUT they do make C clip eliminator kits from ford racing for them.
welding steel tubes to the CAST housing will be quite difficult....
it's been done many times, it's a cast steel not a cast iron.
The factory just used some stamped plugs to keep the tubes from twisting.
it needs to be welded. Many have done it no problems with just a MIG.
Preheat, use nickel rod, cool slowly, good to go.
you have to weld the tubes to the center section on these diffs. I've seen two personally and seen dozens of pictures of spun tubes. Big tires and decent traction will break those little factory welds in no time.
It's an easy and quick process. :cheers:
Here is the deal on welding the tubes to the axle, I have personally done 3 with no failures.
You need to really clean it first
I like to pull the ring gear out (makes it easier to lincoln lock that as wel)
Then i take my propane torch out and pre heat the center chunk, you can buy preheat crayons at a welding supply store to ensure you hit the correct temp you want about 300
Then I make small 1-2" passes moving 180* degrees away from the last weld, until welded all the way around. Then I do a complete cover pass. Repeat for the other side
