thejum57 Posted October 22, 2013 Share Posted October 22, 2013 Drove the truck home from work, stopped on the way went to start it ...nothing. AAA comes tries to jump it...nothing, then the guy gets a screwdriver and starts tapping on the sylenoid and it fires right up. He said I probably need a new one.The NAPA guy said he shows a Ford one for $25.00. Can they be interchanged? I know if I buy it and it doesn't work it's still mine, places won't take back electrical parts. Advance has the right one (I guess) for $100.00 and won't get it until Friday. By the way it has the 2.5l gas engine. Link to comment Share on other sites More sharing options...
jimoshel Posted October 22, 2013 Share Posted October 22, 2013 I've had good luck just taking the old apart and cleaning the contacts. Link to comment Share on other sites More sharing options...
87Warrior Posted October 23, 2013 Share Posted October 23, 2013 Does your truck have a remote solenoid (Ford style) or is it integrated (typical)? The '86 uses either one depending on what you already have. Link to comment Share on other sites More sharing options...
thejum57 Posted October 23, 2013 Author Share Posted October 23, 2013 It's mounted on the inner fender near the battery, has about 5 leads hooked up to a post and 3 push pull connectors. Got home today (drove the other vehicle to work) it started right up. Pulled off all the leads carefully (didn't mix them up) cleaned them and ...nothing. Charged it a bit, still nothing. I need to get a new one. Don't want to pay $100.00 though! I'll get a pic up ASAP. Link to comment Share on other sites More sharing options...
87Warrior Posted October 24, 2013 Share Posted October 24, 2013 Sounds like you can use the cheaper Ford remote style. Link to comment Share on other sites More sharing options...
thejum57 Posted October 24, 2013 Author Share Posted October 24, 2013 Having a real hard time trying to transfer pics. Does the Ford remote style have one big lug, and 3 "push-pull" l connectors? And if so, have you used one? Part store's and or part numbers? Thanks for your help, but I've searched local parts stores and got the same answer...maybe Ford part? Also, do these have to be "stock" parts or can you substitute with an "it fits/it works part:? Or I guess I'm also asking...is a relay , a relay ? Thanks, Jim Link to comment Share on other sites More sharing options...
87Warrior Posted October 24, 2013 Share Posted October 24, 2013 You are trying to replace the starter solenoid. It is probably referred to as a Motorcraft part. When I bought my 86 2.5, it was missing most of the starter electrical system. When I went shopping for parts I was dumbfounded when I came across the Motorcraft stuff so I tried to familiarize myself with it. Lucky for me, I found out my truck utilized the typical solenoid on starter set up, so I have never actually worked with the Motorcraft style. Link to comment Share on other sites More sharing options...
yxmj Posted October 24, 2013 Share Posted October 24, 2013 If it is a remote (mounted on the fender) you can probably replace it with any remote solenoid, do not limit yourself to just Ford. Other manufacturers (Chevy)... (as well as heavy equipment) use the same set up. just make sure you have the same # of terminals EDIT Here is a link.....it is a Chevy unit additional part #'s http://www.autopartswarehouse.com/shop_parts/starter_solenoid/jeep/comanche.html Link to comment Share on other sites More sharing options...
carnuck Posted October 27, 2013 Share Posted October 27, 2013 The way to tell the styles apart. Carbed ones used the Ford style starter and fender mounted solenoid. When they went to TBI they moved the ring gear 3/8" (actually, 10 mm) and went to the solenoid on starter. Link to comment Share on other sites More sharing options...
thejum57 Posted October 28, 2013 Author Share Posted October 28, 2013 It seems that the AAA guy got it wrong. I needed a starter relay. Replaced that, still no go. Got a new battery, old one was 5 years old, started right up!!!! Link to comment Share on other sites More sharing options...
