64 Cheyenne Posted October 16, 2013 Share Posted October 16, 2013 Need a front driveshaft on the cheap. (My slip-stub is worn out) Lots of used out in JY XJs with AW4s I have an AX-15 w 4" lift Specs for the two shafts are: AX-15 29.25" AW4 30.66" = AW4 1.41" longer My question is, can I use the longer shaft from the auto since I have 4" of lift? Anybody ever run this longer shaft (Auto) with their AX-15? Link to comment Share on other sites More sharing options...
mjeff87 Posted October 16, 2013 Share Posted October 16, 2013 That's what I'm running in mine (AX-15 with about 5-6" of lift). No problems here. Jeff Link to comment Share on other sites More sharing options...
onlyinajeep726 Posted October 16, 2013 Share Posted October 16, 2013 What about using an AW4 front shaft on an AX15 with no lift? Will that work? Link to comment Share on other sites More sharing options...
FrankTheDog Posted October 17, 2013 Share Posted October 17, 2013 An AW4 driveshaft will fit with an ax15 but the slip will be all the way in leaving no room to move. Not recommended. Link to comment Share on other sites More sharing options...
carnuck Posted October 17, 2013 Share Posted October 17, 2013 tends to shear the tcase off when you hit a big potthole or speed bump. Link to comment Share on other sites More sharing options...
onlyinajeep726 Posted October 17, 2013 Share Posted October 17, 2013 Ok... so it's either leave it off for now or a lift... I guess since I don't have money for a lift, I'm gonna just leave it off for now... :rolleyes: Link to comment Share on other sites More sharing options...
