Looking To Go To Obd Ii
Anyone know if the 96 cherokee OBDII engine computer is just plug and play substiture for the 95 and earlier OBD1 engine computer?
With my 1996 Passat, the OBDII computer was a plug and play substiture for the OBDI computer.  No extra wiring, just plug and play.
Guess I could just hunt for the 96 computer on Ebay or the Pick and Pull, then plug it in and see if it works.
96 ecu is a completely different style and plugin from the 91-95. not compatible.
The dash harness, engine harness, steering column are all easily put in, the hardest part being making the wires match up at the driver footwell for fuel sending unit. You'd also need to have a H.O. fuel sending unit.
The airbag in the 95-96 has no electronics whatsoever. It is a pendulum style airbag that is activated by sudden momentum, which causes a needle on the pendulum to break a piece of glass, starting a chemical procedure to deploy the airbag.
You can easily do some fancy wiring to keep the gm saginaw column, but then you will NOT be able to use cruise control, as the 96 cruise control is activated by certain resistance through the switches on the face of the steeringwheel. You could mount those switches elsewhere to compensate for it, but frankly, the effort spent to do that vs. simply bolting in the column makes it not worthwhile.
Call Jack at Unichip North America (Hillsboro, OR) @ 1-866-UNICHIP. For your 91, you will need the Unichip "Q" module. It's the hardwired version; there's no PnP Unichip for the Jeep I6 4.0L OBD1 (or OBD2 engine AFAIK). It's pretty easy to wire it into the ECU harness. He can also help you with a tuner in your local AO.
