Well I can't drive my truck for like 2 weeks. On the passenger front I
need a ball joint and driver front I need a wheel bearing. I have a front
axle out of a cherokee that I planned on putting in so I guess I'll be doing
that sooner than I thought. How hard are front axles to put install?
Sean
Easy, disconnect the control arms, brakes (perhaps leave the calipers connected to the brake lines and zip-tie them up to something so you don't have to bleed your brakes), disco the sway bar and steering (if the tie rods don't come off easy, take it off at the steering box and take care of them while it's out of the truck) and drop her down.
haha, make sure you support the frame rails so the truck doesn't nose-dive on top of you...(saw almost kill himself doin that...he had the axle he was taking out supported but not the truck :nuts: )
oh, and grease the hell outta everything when you put it back together. if it's a moving part, chances are it needs to be inspected thoroughly, if not replaced. best time for replacements on Ujoints, hub bearings, and ball joints is while it's out of the truck.
I'll take the negative road on this one.
Front axle swaps suck while working alone. The axle's heavy, and the control arm bolts never want to line up.
Alone, it takes me ~3.5 hours. With a helper, 2 hours. First time alone ~6 hours.
Key's to a painless axle swap:
Have at least 4 jackstads, two for the frame, two for the axle.
Get a large pipe wrench to twist the axle, it greatly helps lining up the control arms.
get spares for the bolts, the donor you get the axle from is a good spot to scavenge. Chances are you're going to have to cut some control arm bolts, I had to cut two. They seized into the bushing sleeve.
Yeah all of that.
It's really not hard, but I was taking the "negative road" as to what someone could see it as.
That is the key to a semi painless axle swap, :D a painless axle swap is findsome with air tools, a 2post lift and a high lift trans / axle jack. Takes about 1 hr :cheers: Also with that setup you can replace the UCA /LCA's in about 30 min. jamminz.gif
Charles
I swapped mine out a couple weeks ago by myself.
The trick to the CA bolts is to leave the arms connected to the frame, and leave the trackbar attached to the frame bracket. To get them reinstalled, hang the axle by the LCA's first. The pinion will be pointing more or less straight upward at that point. Rotate it backward and use a floor jack under the diff to raise the driverside up and pop in the UCA bolt, then reposition the jack on the axletube beside the diff and raise again. The other UCA bolthole will align then. Once the CA are rebolted, put the jack back under the diff and jockey the axle around some until the axle end of the TB lines up and thread the bolt in.
Once that's done, use a bottlejack to install the springs, reconnect the steering, shocks, calipers, sway bar, and stabilizer.
Jeff
