Dirteatr717 Posted August 13, 2013 Share Posted August 13, 2013 I searched through 3 pages of stuff and didnt really find out what I exactly needed to know. I got a brake booster and master cylinder from a buddy that was parting out a 99 XJ. What all is entailed to swap it with the old crap in my 89? Link to comment Share on other sites More sharing options...
87Warrior Posted August 13, 2013 Share Posted August 13, 2013 If you can get the brake peddle assembly it will be 90% bolt in. You will need to fabricate a short bracket to tie the top of the peddle assembly to the original mount behind the dash. '99 XJ booster in '91 MJ (original dash) (dang it, thought I had a picture of the peddle assembly installed) Link to comment Share on other sites More sharing options...
Dirteatr717 Posted August 13, 2013 Author Share Posted August 13, 2013 Darn the XJ is long gone, I haven't looked at the differences but my trucks manual also.. Link to comment Share on other sites More sharing options...
onlyinajeep726 Posted August 13, 2013 Share Posted August 13, 2013 The '95 - '96 XJ boosters are more ideal for this swap since the booster's rod length is pretty much spot on. The '97 - '01s are longer, thus the reason for wanting/needing the pedal assembly. The master cylinders are the same, however, for all '95 - '01s. See if you can get your hands on a '95 - '96 booster and sell or trade yours. Link to comment Share on other sites More sharing options...
1989 Eliminator Posted August 16, 2013 Share Posted August 16, 2013 http://comancheclub.com/topic/39437-1996-xj-dual-diaphragm-brake-booster-conversion/?do=findComment&comment=396974 There ya go! Link to comment Share on other sites More sharing options...
ComancheKid45 Posted August 16, 2013 Share Posted August 16, 2013 Yeah, besides the pedal height being higher its a straight bolt in swap, You also will probably need to make the 2 short brake lines as well between the master cyl. and the distribution block. Link to comment Share on other sites More sharing options...
Crash Posted August 17, 2013 Share Posted August 17, 2013 Yeah, besides the pedal height being higher its a straight bolt in swap, You also will probably need to make the 2 short brake lines as well between the master cyl. and the distribution block. I got parts from a 96, I think dual dia. bosoter/master and also got the matching brake pedal. So no trial and error grinding and fitting the new rod, etc. As far as the lines, you could probably do some sort of adapter/union. I work at carquest so I figure I can test fit and figure all that out before I swap in mine. Link to comment Share on other sites More sharing options...
