Ba10 To Ax15, Now Tcase Linkage Isn't Right?
I upgraded from my pugeot to my aisin without issue, except now the transfer case linkage is out of place by an inch and a half or so (seems the entire bracket that's bolted to the body is too far forward)? Am I the only one with this problem, or have others dealt with it, and if so how?
I've heard of this problem when using an aw4 t-case linkage with any other tranny, like an ax15, because auto tranny/t-case combos are longer. But as far as I know the pukey and ax15 4wd are the same length, thus the linkage should be the same. I know this doesn't help your problem, just stating what I've been told.
Well I think the linkage is exactly the same. What I believe is different is the bracket that's screwed into the body, where the first pivot point of the linkage is located, seems to be too far forward. I could just make a custom linkage like here (http://comancheclub.com/topic/14149-transfer-case-linkage/) but I'd rather not take that time. Just hoping someone knows something I don't.
When I did the same swap I had to snag the linkage bracket for the AW4.  IIRC the TC linkage pivot was built right in to the BA-10.
Since the AW4 is longer, I had to move the body side pivot back about an inch...was not that hard to do as you're only drilling in to the body sheet metal to line up the body side pivot up with the tranny side pivot.
I have a picture of it from Stu's Offroad tranny swap page...but it's on my work computer...I'm on vacation til next week.
Said it time and again....
When doing a BA-10 to AX-15 or 2wd to 4wd,
You need to grab EVERYTHING, the body side bracket is specific to the AX-15
The hole will be towards the rear, right where you need it to be.
If I'm grabbing this from a wrecked Jeep, i use a utility knife to cut the carpet to get the four bolts out.
Thanks for the input guys. I'll look it up. 64 Cheyenne, I bought the comanche with a seized pugeot and an ax15 in the bed that the PO had pulled and never installed, so I just used what I had. Modified my trans crossmember and stuck it in. Now I just have this hurdle and it'll all be gravy. I'm selling the thing anyway.
I decided I'm going to go the custom route and make the DIY Turnbuckle solution that's posted in the DIY section. Thanks for all the input though guys.
That's the direction I started to go at first, what a major PIA...
Spent more time and effort than it was worth, if I calculated time and effort, I could have easily bought one of these:
http://www.novak-adapt.com/catalog/shifters/kit_sk2x.htm
So after all the effort, I went back to a stock linkage, why? because the custom one I did went on the 87 moneypit
and I never got a chance to try it out. Chances are pretty good that I'm gonna buy one of the Novak kits anyway.
BTW I did finish it, goes through all the gears just fine, never tried it out though.
Another reason I decided against it was I got a Terra Low 4:1 with 2Low kit in it and didn't want to mess with anything
that wasn't commercially engineered to shift it.
Cuttin, modifying, welding the lever arms. Just took more time than it was worth.
For ease of getting on the road and cost, you can't beat the stock linkage.
My 88 Chief used to pop out of 4 low till I replaced motor mounts,
I'd still back (use) the stock linkage.
