Frozen Gauges
Was driving home on Sat and all the electrically driven gauges in my cluster froze at odd points. The tach is showing 1800, temp gauge is maxed out, ammeter does not register at all and the fuel gauge is frozen at 1/4 tank even after filling the tank. I checked the fuses and all of them were good.
I will be doing Cruiser's dash ground upgrade in a day or two and wonder if there is a relay I should check as well. Other than that the only other thing I can think of trying is to unplug the cluster and plug it back in to see if that fixes it.
When a gauge such as the temp gauge and/or fuel gauge reads maxed out, isn't that an indication of a short to ground?
Try unplugging the temp sender wire at the sending unit. See if the needle moves down. If not, then i'd suspect an issue with the cluster connection. True enough that a faulty ground wire can cause strange things, so as mentioned above, might refresh the instrument grounds, and clean connections.
  • 4 months later...
