Cheap Way To Fit 33X10.5R15 Tires
I understand the WJ arms are beefier, and allow more room for the tires at full lock, but can't remember if they are longer. I'm wanting to get longer lowers, but don't want to spend for the cost of new adjustable ones. JY WJ ones would be good enough for my needs.
OT. If you shop around on mudflaps.com, you can usually find some pretty good deals on coils.
  On 6/3/2013 at 3:59 AM, Pete M said:
I think that might make it worse by putting the tires into the fenders at full turn..
oh, and add WJ lower control arms to that mix. :thumbsup:
they are not longer, but there is some adjustment in the rear mounting point to push the arm forward.  aftermarket arms with a round cross-section will also work.  they may not allow as much turn, but when the tire hits it won't catch as bad as stock arms.
