Jaime Posted May 9, 2013 Share Posted May 9, 2013 Hello, I'm trying to get my cooling system together and have a question on the hose that goes to the pressure bottle. It seems that both of the hoses that go to pressure bottle have a very small leak. Both of them seem to be fitted hoses. NAPA shows the heater valve, which I can then put regular hoses with clamps. I can't seem to find the other hose that goes to the pressure bottle. My question is can I some how pry the hose off the metal pipe and put regular heater hoses on it or is this something that I have purchase as a unit. It's a 88, 4.0, 5 speed 4x4. Thanks Link to comment Share on other sites More sharing options...
Keyav8r Posted May 9, 2013 Share Posted May 9, 2013 Cut them off with a dremel or cut-off disc on a grinder. Just did mine to replace hoses. Be careful to just cut through the metal band and a little of the hose so that you don't damage the tubing. Link to comment Share on other sites More sharing options...
Jaime Posted May 9, 2013 Author Share Posted May 9, 2013 Seems simple enough. Thanks I don't know how I managed to post this twice. Can someone please delete the other post. Link to comment Share on other sites More sharing options...
cruiser54 Posted May 9, 2013 Share Posted May 9, 2013 And do yourself a favor and eliminate the heater valve. It's not needed and they like to disintegrate at will. Link to comment Share on other sites More sharing options...
Bornindesert Posted May 9, 2013 Share Posted May 9, 2013 The hoses for both the heater valve to bottle and tee to bottle are molded. Both the tee and heater valve are smaller in diameter than the bottle connections, which is why the replacement hose is molded, one end bigger than the other. Just be aware when you size up the heater hose you use to replace it, cut to length. Link to comment Share on other sites More sharing options...
Jaime Posted May 10, 2013 Author Share Posted May 10, 2013 The heater valve has a tee that goes to the top of the bottle. Do I cut the metal part of the heater valve or do I just look for a metal/brass tee to make the appropriate connections. Link to comment Share on other sites More sharing options...
Bornindesert Posted May 10, 2013 Share Posted May 10, 2013 I think the answer is yes. If you have a factory crimped hose, cut through the crimp, remove/replace the hose and use a hose clamp. Link to comment Share on other sites More sharing options...
Jaime Posted May 10, 2013 Author Share Posted May 10, 2013 I'll give it a shot. Thanks again. Link to comment Share on other sites More sharing options...
