drase Posted April 30, 2013 Share Posted April 30, 2013 My 87 4.0 Renix does not have a evap canister or the bracket the secured it. Can someone please post a pic so I know where it goes and how it is attached to the engine bay? And if anyone has one for sale? Link to comment Share on other sites More sharing options...
Keyav8r Posted April 30, 2013 Share Posted April 30, 2013 Go to a local JY/P&P and get one with the brackets, hoses, etc. from a Renix XJ. Link to comment Share on other sites More sharing options...
drase Posted May 1, 2013 Author Share Posted May 1, 2013 Will any years of the XJ fit into MJ? And since I don't have a evap canister I would greatly appreciate a pic of one in the engine bay so I know where to get it and install it.. Link to comment Share on other sites More sharing options...
Keyav8r Posted May 1, 2013 Share Posted May 1, 2013 Not 100% positive but I think 87-89. It is a black cylinder, approx. 7"-8" diameter x 10"-12" deep. Mounted on the passenger side near the firewall (roughly in front of the heater and AC connections at the firewall) with the top at about mid-height of the engine. Has a couple of hoses/vacuum lines attached. Having trouble posting photos, but PM your e-mail and I'll send a picture to you tomorrow. Link to comment Share on other sites More sharing options...
mvusse Posted May 1, 2013 Share Posted May 1, 2013 Renix engine bay (86 through 90) is identical between MJ and XJ. Chrysler (91-92) is also, but different from Renix. So if you get an evap cannister from a Renix XJ, where it was mounted is also where it will mount in your MJ. Link to comment Share on other sites More sharing options...
mjeff87 Posted May 1, 2013 Share Posted May 1, 2013 firewall, beside and a little below the HVAC blower motor: Image Not Found Link to comment Share on other sites More sharing options...
87sparTruck Posted May 2, 2013 Share Posted May 2, 2013 Yup I just removed one from my 89 4.0 MJ parts truck. It has 3 bolts holding it to the inner fender/wheel well in front of the blower motor. Link to comment Share on other sites More sharing options...
MJRemi Posted May 2, 2013 Share Posted May 2, 2013 I have the bracket I can sell but the canister is from a 86 and is slightly different in design although size is the same. Since the canister processes fuel vapor, be sure to use correct size fuel rated rubber lines to prevent corrosion of the hoses. Link to comment Share on other sites More sharing options...
ParadiseMJ Posted May 2, 2013 Share Posted May 2, 2013 Right behind the...wait...where's the engine?? firewall, beside and a little below the HVAC blower motor: Image Not Found Link to comment Share on other sites More sharing options...
mjeff87 Posted May 3, 2013 Share Posted May 3, 2013 LOL....that pic was taken in the middle of the 2.5-to-4.0 engine swap project. Link to comment Share on other sites More sharing options...
87sparTruck Posted May 3, 2013 Share Posted May 3, 2013 Hmm just looked at mjeff's picture and my canister was actually infront of the blower motor unlike his. Might be the motor's causing the location change. I can check my 87 2.5 unless someone know's why. Link to comment Share on other sites More sharing options...
Keyav8r Posted May 3, 2013 Share Posted May 3, 2013 mjjeff's canister location is like my 88 4.0. Directly inline with the heater core inlet/outlet. Link to comment Share on other sites More sharing options...
drase Posted May 8, 2013 Author Share Posted May 8, 2013 Hmm just looked at mjeff's picture and my canister was actually infront of the blower motor unlike his. Might be the motor's causing the location change. I can check my 87 2.5 unless someone know's why. Could u post a pic please of your 87? Or if anyone else has a 87 that can post a pic of their evap canister location? Link to comment Share on other sites More sharing options...
