88whitemanche Posted April 27, 2013 Share Posted April 27, 2013 Hey guys Does anyone have pics of one with a 4 cylinder? I'm trying to figure out how it mounts on the frame because it seems to be block by the front motor mount Link to comment Share on other sites More sharing options...
mnkyboy Posted April 27, 2013 Share Posted April 27, 2013 I will see if I can get some pics of mine. It doesn't interfere with any mounts but it does bolt down in same spot as the vibration dampener on the passenger side. You just put the skid plate on then the dampener mount goes over it. Link to comment Share on other sites More sharing options...
88whitemanche Posted April 27, 2013 Author Share Posted April 27, 2013 Is it hard to remove that dampener? Or is it that simple to just remove the three bolts and reattach them again with the skid plate? Link to comment Share on other sites More sharing options...
mnkyboy Posted April 27, 2013 Share Posted April 27, 2013 That's pretty much it. Link to comment Share on other sites More sharing options...
mnkyboy Posted April 28, 2013 Share Posted April 28, 2013 Here is a pic of the skid plate and the mount Link to comment Share on other sites More sharing options...
dasbulliwagen Posted April 28, 2013 Share Posted April 28, 2013 I wondered about this exact thing a while back when I tried to look to see if it would mount up and saw that the damper was in the way. Glad theres a simple solution! Link to comment Share on other sites More sharing options...
onlyinajeep726 Posted April 28, 2013 Share Posted April 28, 2013 Quick question, kind of off topic but sort of related. That dampener... why is it used on the 4-banger but not the 4.0? Link to comment Share on other sites More sharing options...
88whitemanche Posted May 23, 2013 Author Share Posted May 23, 2013 I read that it's sapose to help with the engine vibration...also monkyboy I have a question about the other side of the vibration dampene. is the hole sapose to be threaded or did you thread it yourself? Because I look into the hole and its not threaded and since its in the frame rail I don't want to poke holes that's not nessacery.... Link to comment Share on other sites More sharing options...
mnkyboy Posted May 23, 2013 Share Posted May 23, 2013 As far as I know all that stuff is stock on mine. Link to comment Share on other sites More sharing options...
88whitemanche Posted May 23, 2013 Author Share Posted May 23, 2013 Crap!!!!! Wait! I ended saving the bolts from the cherokee I took it off of and bam it fits!!!!! Before! And after!!! Link to comment Share on other sites More sharing options...
