Wrz Posted April 22, 2013 Share Posted April 22, 2013 Empty Post Link to comment Share on other sites More sharing options...
onlyinajeep726 Posted April 22, 2013 Share Posted April 22, 2013 Hood light, I believe. Possibly cruise control vacuum mechanism. Horn wire... should be gray. Electric fan plug. Windshield washer fluid level sensor. Link to comment Share on other sites More sharing options...
87manche1 Posted April 22, 2013 Share Posted April 22, 2013 One by vacuum res. ( air bubble) is probly for a horn Link to comment Share on other sites More sharing options...
87manche1 Posted April 22, 2013 Share Posted April 22, 2013 Edit Link to comment Share on other sites More sharing options...
onlyinajeep726 Posted April 22, 2013 Share Posted April 22, 2013 Do I get a prize for getting these right? :dunce: Link to comment Share on other sites More sharing options...
ftpiercecracker1 Posted April 22, 2013 Share Posted April 22, 2013 Edit Link to comment Share on other sites More sharing options...
ftpiercecracker1 Posted April 22, 2013 Share Posted April 22, 2013 Electric fan plug. Electric fan switch plug, the one that goes in the lower radiator bung, all the rest were correct. Link to comment Share on other sites More sharing options...
onlyinajeep726 Posted April 22, 2013 Share Posted April 22, 2013 Electric fan plug. Electric fan switch plug, the one that goes in the lower radiator bung, all the rest were correct. Yes, you are correct. I was thinking that in my head but it didn't quite make it to my fingers haha. Link to comment Share on other sites More sharing options...
Wrz Posted April 22, 2013 Author Share Posted April 22, 2013 Thanks for all the quick responses and help, guess I need a hood light and a horn now since mine are missing, going to see if I can wire in the fan later, Any idea what the green wire is for or where it does? Link to comment Share on other sites More sharing options...
ftpiercecracker1 Posted April 23, 2013 Share Posted April 23, 2013 There should be two wires for the horns. One on the driver and passenger side, both will be grey. Green wire with a white stripe, :dunno: Link to comment Share on other sites More sharing options...
Wrz Posted April 24, 2013 Author Share Posted April 24, 2013 Hey sorry for the confusion, i think i identified the green wire with the white strip, I was looking over my stater solenoid and am missing the wire that goes to the starter solenoid terminal, but am also missing the wire that goes to my starter, so i have one wire that looks like it goes to two spots? :???: Any ideas? It was duct taped spliced when i pulled my motor and removed the splice with out seeing where it goes here are a few pictures the harness that the wire comes out of and figured out why i can find the washer fluid sensor plugin Will see if i can score one from the j/y with a sensor port thanks and hopefully i can figure this out by the weekend so i can attempt to fire her up for the first time :cheers: . :MJ 1: . Link to comment Share on other sites More sharing options...
ftpiercecracker1 Posted April 24, 2013 Share Posted April 24, 2013 Hey sorry for the confusion, i think i identified the green wire with the white strip, I was looking over my stater solenoid and am missing the wire that goes to the starter solenoid terminal, but am also missing the wire that goes to my starter, so i have one wire that looks like it goes to two spots? :???: Any ideas? It was duct taped spliced when i pulled my motor and removed the splice with out seeing where it goes here are a few pictures the harness that the wire comes out of Yes, your on the right track. I will check mine out tomorrow and report back. I know that green/wht wire has something to do with the starter, i just have to see how its routed. Link to comment Share on other sites More sharing options...
Wrz Posted April 24, 2013 Author Share Posted April 24, 2013 Hey I would really appreciate it, I've searched google and checked my local Jy but have come up with nothing Thanks Link to comment Share on other sites More sharing options...
ftpiercecracker1 Posted April 25, 2013 Share Posted April 25, 2013 Alrighty here we go. This is where your Green/wht stripe wire ENDS Image Not Found From there it goes to a large grey (gray?) plug Image Not Found Image Not Found Comes out and . . . Image Not Found Makes an immediate U turn and goes into a large Black Plug Image Not Found Image Not Found I did not trace it from there, but can if need be. Of the three large wires, here. . . . Image Not Found There are two more large solid green wires. One that goes exactly where you thought it should. . . her Image Not Found Image Not Found and the other goes to your Starter Image Not Found Link to comment Share on other sites More sharing options...
Wrz Posted April 25, 2013 Author Share Posted April 25, 2013 Thanks that really helps me out, so pretty much I take the end of the wire and split it into two, one going to the solenoid and the other to my starter? Alrighty here we go. This is where your Green/wht stripe wire ENDS Image Not Found From there it goes to a large grey (gray?) plug Image Not Found Image Not Found Comes out and . . . Image Not Found Makes an immediate U turn and goes into a large Black Plug Image Not Found Image Not Found I did not trace it from there, but can if need be. Of the three large wires, here. . . . Image Not Found There are two more large solid green wires. One that goes exactly where you thought it should. . . her Image Not Found Image Not Found and the other goes to your Starter Image Not Found Link to comment Share on other sites More sharing options...
Wrz Posted April 25, 2013 Author Share Posted April 25, 2013 Think it's weird that every jeep I traced the wire back either had a electrical nut or some duct tape on it lol Link to comment Share on other sites More sharing options...
ftpiercecracker1 Posted April 25, 2013 Share Posted April 25, 2013 Ya, I found the equivalent of an entire roll of silver duct tape while tearing apart my engine bay wire harness, it was all from the factory. Link to comment Share on other sites More sharing options...
Wrz Posted April 25, 2013 Author Share Posted April 25, 2013 Ya, I found the equivalent of an entire roll of silver duct tape while tearing apart my engine bay wire harness, it was all from the factory. I'm going to get her all wired up properly tomarrow, and hopefully she will fire up this weekend for its first time Link to comment Share on other sites More sharing options...
