ComancheKid45 Posted March 22, 2014 Share Posted March 22, 2014 Very good work! Truck looks great! Link to comment Share on other sites More sharing options...
AeroNautical Posted March 23, 2014 Author Share Posted March 23, 2014 Much appreciated, here are a few more shots in her natural environment: A tree I knocked down by mistake: Until I can figure something out with my front fender flares, I have to leave my front sway bar connected so I don't flex too much. It takes alot, but they do rub. Link to comment Share on other sites More sharing options...
KCsurfer420 Posted March 26, 2014 Share Posted March 26, 2014 One solution would be to bump stop it propperly Link to comment Share on other sites More sharing options...
AeroNautical Posted March 27, 2014 Author Share Posted March 27, 2014 One solution would be to bump stop it propperly It doesn't rub when steering, only when flexing. Edit: Misread your post. When flexing it doesn't rub in the wheel well, only on the front of the fender. I'm just gonna take a saw zaw and chop it off to fix the problem. It is bump stopped properly, though. Link to comment Share on other sites More sharing options...
AeroNautical Posted April 7, 2014 Author Share Posted April 7, 2014 Got the chance to chop my front fenders. It's a bit crude, but works well: Before: After: It's close, but no rubbing! Link to comment Share on other sites More sharing options...
AeroNautical Posted May 16, 2014 Author Share Posted May 16, 2014 I installed my bumper, not my first choice, but a good choice no less! The old aluminum steering spacer vs the new steel reinforced spacer from JCR: The uni-frame tie in brackets: You can see the beefier tie rod I installed a few weeks back: 12,000 pound winch in a few more weeks. I'm very happy with this bumper. Link to comment Share on other sites More sharing options...
onlyinajeep726 Posted May 28, 2014 Share Posted May 28, 2014 Just went through your entire build thread... Impressive work man. Can't wait to see this Sunday at Uwharrie. Makes me really want to do SOA rear and lift mine. Link to comment Share on other sites More sharing options...
Rymanrph Posted June 3, 2014 Share Posted June 3, 2014 If you guys go to Uwharrie and want some more MJ company, let me know. I'm only 40 minutes away. I need to get mine back out on the trails. Link to comment Share on other sites More sharing options...
AeroNautical Posted June 4, 2014 Author Share Posted June 4, 2014 If you guys go to Uwharrie and want some more MJ company, let me know. I'm only 40 minutes away. I need to get mine back out on the trails. You just missed a trip last sunday. We didn't get to wheel together, but did get to BS for a few minutes about toyota prius'. Link to comment Share on other sites More sharing options...
outlaw star Posted July 2, 2014 Share Posted July 2, 2014 Great looking truck brother. Hooah! Link to comment Share on other sites More sharing options...
AeroNautical Posted August 19, 2014 Author Share Posted August 19, 2014 Thanks! I finally got around to putting new rims on her, they have a wider offset now. This is with 1.5 inch spacers, I may take em off depending on if I rub the fender flexing. That little step stool didn't do much, though! I get the center caps in a few days. This was almost a little embarrassing, haha: Link to comment Share on other sites More sharing options...
AeroNautical Posted August 31, 2014 Author Share Posted August 31, 2014 Installed my winch today, chose a 9000 lbs Badlands over the 12000 pounder because it has a faster reel speed, and I can't think of a scenario where I'd need 12000 lbs. I'm almost done with my project, all that's really left are the seats, lighting and some engine mods. Link to comment Share on other sites More sharing options...
AeroNautical Posted October 2, 2014 Author Share Posted October 2, 2014 I scored at the JY the other day, got two butterfly buckets from an XJ in great shape, just a bit dirty. Spent a few days scrubbing and cleaning them, letting them sit in the sun, swapping brackets and just today putting them in the MJ. Unfortunately, they are from a 4 door, but I've spent the better part of a year looking for the ideal 2 door XJ seats with no luck, plus I rarely went behind the seats anyway. I've got my fire extinguisher, beater stick, winch control and CDs behind the passenger seat within reach from the drivers seat. THIS is why I needed new seats, haha. Passenger side is almost perfect, but the drivers is absolute $#!&e: For reference, this is the bracketry difference between the XJ (left) and MJ (right): SO glad to finally have this done. Link to comment Share on other sites More sharing options...
Rymanrph Posted October 2, 2014 Share Posted October 2, 2014 I had the "butterfly" seats first but they were way too tall for me. When I finally found the 2 door XJ buckets I couldn't pass them up even though the covers were in rough shape. Keep in mind that if you find the right seats, the tilt mechanism will swap over. Link to comment Share on other sites More sharing options...
AeroNautical Posted October 2, 2014 Author Share Posted October 2, 2014 I had the "butterfly" seats first but they were way too tall for me. When I finally found the 2 door XJ buckets I couldn't pass them up even though the covers were in rough shape. Keep in mind that if you find the right seats, the tilt mechanism will swap over. Tall? These sit the same as the MJ buckets, these had the flat brackets, though, not the rockers. I still have my MJ buckets, would it be easy to move the tilt function over from them to the XJ seats? Link to comment Share on other sites More sharing options...
onlyinajeep726 Posted October 2, 2014 Share Posted October 2, 2014 Could you just swap the grey covers over from the XJ seats onto the MJ seats? Then all you'd have to do is cut a slit in the side for the tilt-forward lever. Link to comment Share on other sites More sharing options...
AeroNautical Posted October 7, 2014 Author Share Posted October 7, 2014 I thought about swapping the frames out so I could still have the tilt function, but it's really not worth the effort right now. So far the only time I wish the seats would fold forward was when I was installing them. Link to comment Share on other sites More sharing options...
AeroNautical Posted November 16, 2014 Author Share Posted November 16, 2014 Just got a bored TB from Jeff Leigh on stokedjeeps, and was impressed with the results. Quicker response, more power for less throttle, worth the upgrade for sure, especially on my once hydrolocked, 26 year old renix motor. Ever since my water incident, the ol 4.0s been runnin on borrowed time. I'll take care of it until it dies, which is not that far off. SO, who's wantin to part with a nice stroked 4.7? Link to comment Share on other sites More sharing options...
AeroNautical Posted January 5, 2015 Author Share Posted January 5, 2015 Did an AAL today: Link to comment Share on other sites More sharing options...
onlyinajeep726 Posted January 5, 2015 Share Posted January 5, 2015 Am I to assume that pinion/driveshaft angle is so bad due to it being at full droop? :crossfingers: Link to comment Share on other sites More sharing options...
AeroNautical Posted January 5, 2015 Author Share Posted January 5, 2015 The angle's almost perfect when it's on the ground, no vibes. Plus it's still got the slip yoke, not a SYE, so the axle side angle needs to be the same as the t-case angle, which it is for the most part. Link to comment Share on other sites More sharing options...
AeroNautical Posted March 27, 2015 Author Share Posted March 27, 2015 Me an onlyinajeep726 just did an engine swap on the old girl. Swapped to HO and adapted to a renix system. It just occurred to me I don't have any photos of the finished product, I'll have to take one tomorrow. The old block saying goodbye to her prior owner: The fleet: Link to comment Share on other sites More sharing options...
AeroNautical Posted July 29, 2015 Author Share Posted July 29, 2015 New paint! Never did like the Camo all too much. Inspiration comes from Comanche County: http://comancheclub.com/user/2160-comanche-county/ Link to comment Share on other sites More sharing options...
AeroNautical Posted November 19, 2015 Author Share Posted November 19, 2015 It's been a little while since I've updated this. Buncha new stuff. Most notable are the OEM rollbar, LEDs and rear bumper: JCR DIY rear MJ bumper. Figured it'd be a fun welding project... Don't make fun of my beads. Battle scars from my once near perfect body MJ, feel kinda bad, haha. Buds bad @$$ YJ: Link to comment Share on other sites More sharing options...
onlyinajeep726 Posted November 20, 2015 Share Posted November 20, 2015 Sweet man! Can't wait to see this thing again in person soon! Link to comment Share on other sites More sharing options...
