RockinMJ Posted April 14, 2013 Share Posted April 14, 2013 Since I have the motor out thought the least I could do was put new gasket kit on it. It has 220,000 miles on it. Needing a good recomendation for a good complete gasket kit. Thanks Link to comment Share on other sites More sharing options...
Geonovast Posted April 14, 2013 Share Posted April 14, 2013 Last time I bought a complete kit, I got a Felpro, which ran me about $140ish.Make sure you get the rubber gaskets for oil pan and valve cover. A bit more expensive, but it is worth it many times over. Link to comment Share on other sites More sharing options...
Keyav8r Posted April 15, 2013 Share Posted April 15, 2013 What Geonovast said! Link to comment Share on other sites More sharing options...
92tanMJ Posted April 15, 2013 Share Posted April 15, 2013 Last time I bought a complete kit, I got a Felpro, which ran me about $140ish. Make sure you get the rubber gaskets for oil pan and valve cover. A bit more expensive, but it is worth it many times over. This one? http://www.summitracing.com/parts/fel-hs26211pt/overview/make/jeep Link to comment Share on other sites More sharing options...
RockinMJ Posted April 15, 2013 Author Share Posted April 15, 2013 Found a complete set from Sealed Power 119.00 shipped. It is a complete kit. The felpro kits are not complete. Link to comment Share on other sites More sharing options...
Alexia Posted April 15, 2013 Share Posted April 15, 2013 Found a complete set from Sealed Power 119.00 shipped. It is a complete kit. The felpro kits are not complete.That is exactly what I bought. Not only it is a complete kit, but it covers ALL 4.0L engines from 1984 to 2006! There will be left over gaskets for different types of water pumps and thermostat housings. My only issue with the kit is the cheap paper gasket for the water pump has started to leak already. Link to comment Share on other sites More sharing options...
RockinMJ Posted April 15, 2013 Author Share Posted April 15, 2013 Thanks for the responses. I believe i will go with the Sealed Power and maybe get a different different water pump gasket . Link to comment Share on other sites More sharing options...
JeepcoMJ Posted April 15, 2013 Share Posted April 15, 2013 I've never not had enough gaskets in a fel-pro gasket set. the only thing they shunt on is the other 6 injector o-rings. Link to comment Share on other sites More sharing options...
92tanMJ Posted April 15, 2013 Share Posted April 15, 2013 Well I'm going to need to buy one here in the next month or so..and I'm kinda confused on which is the best bang for your buck one.. :hmm: Link to comment Share on other sites More sharing options...
Alexia Posted April 15, 2013 Share Posted April 15, 2013 Federal Mogul = Fel-Pro = Sealed Power The Sealed Power set has Fel-Pro branded gaskets and Sealed Power gaskets which are just Fel-Pro gaskets with a different name. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted April 15, 2013 Share Posted April 15, 2013 yup. aside from ordering specific thickness head gaskets for strokers, I just get my gaskets from the local parts store. Link to comment Share on other sites More sharing options...
92tanMJ Posted April 15, 2013 Share Posted April 15, 2013 Federal Mogul = Fel-Pro = Sealed Power The Sealed Power set has Fel-Pro branded gaskets and Sealed Power gaskets which are just Fel-Pro gaskets with a different name. yup. aside from ordering specific thickness head gaskets for strokers, I just get my gaskets from the local parts store. Gotcha. Do you guys know if I order a master rebiuld kit, if it should have all the gaskets I need? Link to comment Share on other sites More sharing options...
JeepcoMJ Posted April 15, 2013 Share Posted April 15, 2013 it will have all the gaskets. If you want rings and all, I recently installed one of the kits in the link below for a friend's WJ, awesome high quality kit with zero issues, EVERYTHING you need to rebuild a 4.0, and great customer service....fast shipping, too http://www.ebay.com/itm/JEEP-Premium-Master-Engine-Rebuild-Kit-242-4-0-1999-/300765588830?pt=Motors_Car_Truck_Parts_Accessories&fits=Make%3AJeep&hash=item460706ad5e&vxp=mtr Link to comment Share on other sites More sharing options...
JeepcoMJ Posted April 15, 2013 Share Posted April 15, 2013 search on ebay though for the correct kit for your MJ or XJ 4.0 for the proper year your parts are going into/came out of. that kit is for a 99 wj, and they can be had cheaper if you search. Link to comment Share on other sites More sharing options...
92tanMJ Posted April 16, 2013 Share Posted April 16, 2013 it will have all the gaskets. If you want rings and all, I recently installed one of the kits in the link below for a friend's WJ, awesome high quality kit with zero issues, EVERYTHING you need to rebuild a 4.0, and great customer service....fast shipping, too http://www.ebay.com/itm/JEEP-Premium-Master-Engine-Rebuild-Kit-242-4-0-1999-/300765588830?pt=Motors_Car_Truck_Parts_Accessories&fits=Make%3AJeep&hash=item460706ad5e&vxp=mtr search on ebay though for the correct kit for your MJ or XJ 4.0 for the proper year your parts are going into/came out of. that kit is for a 99 wj, and they can be had cheaper if you search. I saw on of those for my motor and wondered if anyone has used them. I was also looking at this one http://www.flatlanderracing.com/rebuildkitsamc.html Edit: http://www.ebay.com/sch/i.html?_from=R40&_sacat=0&_nkw=JEEP+Master+Engine+Rebuild+Kit+242+4.0+1992&_sop=15 I'm honestly lost when it comes to what kit to get and which one is a good kit without over paying and I know its a pay for what you get kinda deal. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted April 16, 2013 Share Posted April 16, 2013 pretty much, so long as the metal parts aren't chinese cheapos, they will all work with no issues. Link to comment Share on other sites More sharing options...
92tanMJ Posted April 16, 2013 Share Posted April 16, 2013 pretty much, so long as the metal parts aren't chinese cheapos, they will all work with no issues. Well I'm gonna stop posting in RockinMJ's thread hahah lll start my own thread when I'm about to order everything. Thanks for you help RockinMJ: Lol sorry man. Link to comment Share on other sites More sharing options...
