New Booster... Fluid Leaking.
I put in a Brake booster and master cylinder from a 98 Cherokee in today, got the brake lines routed and all the mods needed to make it work.. I'm not sure if I'm supposed to use the stock Prop valve (right next to booster) or was I suppose to grab the one from the XJ?
If I could keep the old one (stock) what flare is needed for the brake line on the rear fitting? (towards the rear of the truck)
I might have done the wrong flare (double flare?)
Thanks.
I think you mean distribution block, this right?
Image Not Found
Its probably called both, distribution block is just what i have heard and use. :dunno:
Find a cherokee with non abs brakes and pull off the lines that go to the master cylinder. Ignore what is outlined, look at the Master cylinder. Do you see the brake lines running to the distribution block? Those are the ones you need, they are direct bolt on without having to do all the crazy bending by hand. I did this TODAY on my 90 eliminator.
As for flares, the ones going INTO the DB are double, the ones going INTO the MC, those are "bubble".
I don't like reusing old brake lines except for emergency. The easiest way is to pull the new (used 96 XJ) master cylinder with the lines, pull off the old lines from the existing distribution block, then bend new 3/16" lines from the master to the block reusing the existing brake line fittings. All double flared.  Cake.
Hmm, I think my master cylinder has developed skin cancer.
I have new lines. I just re used the connectors.. I did bubble flare the lines going into the master cylinder... are those supposed to be double also?
I don't think that would cause the fluid to be coming out of the connector
You used a 98 Master so IDK. I just matched the flares from the old lines into each new line. When working with flare nuts, it's a good idea to use flare wrenches to torque them down. They grip on four sides too so less chance of cracking/stripping it.
What did you get your brake lines off of?  Something i learned on this is that my MJ had much larger brake lines than any of the other jeeps i found at the JY, even though the fitting would still tighten down it did nothing to clamp the flare to the DB. I had to find fittings that matched my brake line dia.
I will try to take a picture to show you what i am talking about.
I got new brake lines at the parts store.. apparently I have been doing double flares wrong... I'm going to have to rent the right tool and see if it will help. I think I have been doing single flares..
Alright guys, I'm about to give up on this.. I re flaired the line FOUR TIMES! It is still coming out of the same place.. Am I missing something with this master cylinder/booster? It is a 98-00 one, it is longer than the WJ ones.. Anyone help please. lol
Are u using the little round flare piece to measure and make sure you don't have too much or too little brake line sticking thru the flaring tool before you start to flare. Too much or too little line will make the flare not press into the fitting properly and not seal right causing the leak.
Also, if you have a cheap flaring tool (like mine) and tighten it down too tight on the brake line it will warp the line causing a bad fit. Ask me how I know?
  On 3/28/2013 at 1:07 AM, Bignuke said:
I have done all those things.. I looked at how much thread is actually going into the DB and its not that much.. maybe 1 or 2 full threads.. I'm thinking my DB is stripped..
If all your other new flares are not leaking, then I'd say that's a good possibility.
