Fender Flares
I'm not familiar with NAPA, mine came from Fastenal. Trim the broken studs off with a cut off disc or equivalent. Thoroughly remove rust from surface and tack weld replacement bolt, good to go.
I was able to salvage a few of the nuts using an industrial strength penetrating oil, Kroil.
The web address is on the bottom of the can, WWW.KANOLABS.COM. Pricey but an excellent penetrant.
Original nut...
I believe this is an OEM replacement nut but strongly suggest size verification.
http://www.clipsandfasteners.com/6_1_0mm_10mm_Hex_Head_Nuts_19mm_Loose_Washer_p/pas5915-25.htm
Replacement nut with washer.
LEFT SIDE
Front Retainer: http://www.quadratec.com/products/52449_0174.htm - MOPAR 55003233
Center/Top Retainer: http://www.quadratec.com/products/52449_0175.htm - MOPAR 55003234
Rear Retainer: http://www.quadratec.com/products/52449_0177.htm - MOPAR 55003237
RIGHT SIDE
Front Retainer: http://www.quadratec.com/products/52449_0173.htm - MOPAR 55003232
Rear Retainer: http://www.quadratec.com/products/52449_0176.htm - MOPAR 55003236
$51.94 for a complete set or just buy the pieces you need.
Just be glad you broke the retainers on a 1984-1996 XJ/MJ. 1997-2001 retainers are dealership only and cost $300 for a set.
