Biotex Posted March 12, 2013 Share Posted March 12, 2013 Getting ready for paint, and noticed that there are some plastic rivets of some type used to attach the rubber mud flaps and skirting onto the fronts of the MJ. I'm wanting to remove the flaps/skirting for paint prep, and to be able to get to the front bumper bolts. What are you guys using to replace these fasteners with on reassembly? I'm assuming they are OEM??? Link to comment Share on other sites More sharing options...
Akula69 Posted March 12, 2013 Share Posted March 12, 2013 I use this place, and have had great success finding exact matches to OEM fasteners at a low price. Unfortunately, some of the fasteners come in large quanities... http://www.clipsandfasteners.com/Push_Type_Retainers_At_Clipsandfasteners_com_s/154.htm Link to comment Share on other sites More sharing options...
ParadiseMJ Posted March 12, 2013 Share Posted March 12, 2013 I scored all my panel fasteners at my local ACE hardware. The ones that hold the "vent" on the b pillar, the ones for the splash gaurd, even the ones that hold the plastic trim to the side of the seat bottom. If you have a decent hardware store with a decent nut/bolt/screw department, they'll probably have them. There might even be some in the HELP! section at NAPA, AutoZone, Oreilly's etc. Link to comment Share on other sites More sharing options...
sinkrun Posted March 12, 2013 Share Posted March 12, 2013 Got mine on ebay they also make a tool for removing them that most of the time will not damage them. Link to comment Share on other sites More sharing options...
Biotex Posted March 12, 2013 Author Share Posted March 12, 2013 I use this place, and have had great success finding exact matches to OEM fasteners at a low price. Unfortunately, some of the fasteners come in large quanities... http://www.clipsandfasteners.com/Push_Type_Retainers_At_Clipsandfasteners_com_s/154.htm Thanks for the link. I scored all my panel fasteners at my local ACE hardware. The ones that hold the "vent" on the b pillar, the ones for the splash gaurd, even the ones that hold the plastic trim to the side of the seat bottom. If you have a decent hardware store with a decent nut/bolt/screw department, they'll probably have them. There might even be some in the HELP! section at NAPA, AutoZone, Oreilly's etc. We don't have an ACE here, but we do have an Autozone. Will check out the Help section, but don't remember seeing anything like that before. Thanks for the ideas. Got mine on ebay they also make a tool for removing them that most of the time will not damage them. Do you remember what the fasteners were called? Are they a rivet? Link to comment Share on other sites More sharing options...
johnj92131 Posted March 12, 2013 Share Posted March 12, 2013 I also need to get the fastners for the inner liner. Found these on Ebay: http://www.ebay.com/itm/50-Jeep-Grand-Cherokee-Fender-Liner-Clips-6506293AA-/400313202933?pt=Motors_Car_Truck_Parts_Accessories&hash=item5d3486b8f5&vxp=mtr They look like the right item to me. Link to comment Share on other sites More sharing options...
Biotex Posted March 12, 2013 Author Share Posted March 12, 2013 Ok, so mine are not factory. Unless they changed, mine look like big plastic rivets. I'll see if I can get a picture of them. No wonder you guys are pointing me to Autozone and hardware stores. The push in fasteners like you posted are everywhere, as in easy to find. Mine are not. I have never seen anything like them before in automotive use, so that is why I asked. Link to comment Share on other sites More sharing options...
Biotex Posted March 12, 2013 Author Share Posted March 12, 2013 After looking a bit closer, I have seen thees fasteners before. They press in, then the center pin pushes in and spreads the back side wider. Here is a shot of them. I'm thinking they are reusable if I can pull up on the pin. If not, no reason to not use the other kind mentioned... Link to comment Share on other sites More sharing options...
Keyav8r Posted March 12, 2013 Share Posted March 12, 2013 BMW also uses the fastener in your photo for inner fenders, etc. I had to replace some when my bride located a curb with the front air dam on her Z4. Link to comment Share on other sites More sharing options...
1987Comanche Posted March 13, 2013 Share Posted March 13, 2013 You don't need to remove those 4 plastic pop rivets. They merely hold the soft part of the inner fender to the molded plastic part of it. Fold the soft flaps towards the outer edge of the fender, then pull/roll it out of the way. It will hang down out of the way and you can access the front bumper bolts & horns. Link to comment Share on other sites More sharing options...
54bobby Posted March 13, 2013 Share Posted March 13, 2013 web site for clips http://www.clipsandfasteners.com/Chrysler_Jeep_Clips_Fasteners_Retainers_s/66.htm Link to comment Share on other sites More sharing options...
Biotex Posted March 13, 2013 Author Share Posted March 13, 2013 You don't need to remove those 4 plastic pop rivets. They merely hold the soft part of the inner fender to the molded plastic part of it. Fold the soft flaps towards the outer edge of the fender, then pull/roll it out of the way. It will hang down out of the way and you can access the front bumper bolts & horns. Sounds like wisdom coming from a man with lots of experience? :yes: Link to comment Share on other sites More sharing options...
1987Comanche Posted March 13, 2013 Share Posted March 13, 2013 Yep...after 3-4X you get pretty good at it ;) . The tough part is keeping track of the tow hook brackets. There's a funky nut that goes in the frame stub just behind the alternator. Keep close track of that...easy to lose if you forget it's not welded to the frame. Link to comment Share on other sites More sharing options...
