Starts Then immediately stops
As the title says starts then stops?
I was going to try replacing the cps but I can't figure how to get to it! :mad:
New wires plugs cap rotor..
New ceramic fuel pump ballast resistor [broke that the other day]
I replaced brake mc and booster last night.
ummm not sure what else well thanks....
I still think you've got a fuel pump power problem.
When you turn the key to start the ignition bypasses the ballast resisotr, giving 12V to the pump. When it goes back to run it runs it through the adition circuit for the ballast resistor.
I agree on bypassing the resistor to rule it out.
That's normally what causes that.
Agreed. If it starts, it isn't the CPS, and probably not the IAC or TPS. As noted, the START circuit bypasses the fuel pump resistor. Once you release the key to the RUN position, the power is routed through the resistor. Either the resistor is bad, or there's another problem in that part of the fuel pump circuit.
You could also try running a hot wire directly to the fuel pump. If it starts and stays running, do NOT leave it that way, because you won't have a pressure switch to shut the pump off when there's sufficient pressure in the fuel rail. Hot wire it only as a diagnostic aid.
