martin809 Posted March 8, 2013 Posted March 8, 2013 I am going to install a 99 8.25 in my MJ. I am wondering what perches everyone is using and where did they get them. I went to the dealership and was told they could not order them. I am also wondering placement on the axle. how far in. The old ones are already cut off. Thanks for your time.
Bmoore2 Posted March 8, 2013 Posted March 8, 2013 I got the complete axle install kit from Barnes4wd. I cannot help you on placement. Sorry
Eagle Posted March 8, 2013 Posted March 8, 2013 The dealership CAN order them. They are in the Mopar Performance catalog, and I have posted the part number several times in the past. They are by FAR the best deal going. The Mopar part sells for about one-third what anybody else gets, they come as a pair (when you see the price, you'll be sure it's only for one perch), and they are MUCH heavier-duty than the perches on the stock axles. That's because they are made for building heavy-duty axles in race cars that put a lot of torque to the ground. Found it: The ones from the Mopar Performance Catalog are heavier-duty and cost less than half as much.http://www.mopar.com/assets/pdf/performance/catalog/Steering_Suspension_&_Brakes.pdfScroll to the top of page 10
HOrnbrod Posted March 8, 2013 Posted March 8, 2013 You don't need no steenking dealer for these. Get them here (and elsewhere, search the part number): http://www.jegs.com/i/Mopar+Performance/312/P4120074/10002/-1?CAWELAID=1710617200&catargetid=1784155608&&cagpspn=pla&gclid=CKnv8oCe7rUCFbOoPAodxzEAiw
misfitmechanic Posted March 9, 2013 Posted March 9, 2013 I installed a dana 44 in the rear of my mj and used spring perches from TMR customs. They have three holes in them to fine tune your wheelbase if needed and there a bit longer. This helps support more of the spring to help with wheel hop.
Biotex Posted March 9, 2013 Posted March 9, 2013 This helps support more of the spring to help with wheel hop. I think you mean axle wrap not wheel hop. I used Barnes 4wd also, and they too have the three holes so you can fine tune your wheelbase. They are also longer as well.
mvusse Posted March 9, 2013 Posted March 9, 2013 If you stay spring under, I would get cheap stock style perches. Mopar performance, Jegs, Summit racing.... If going SOA, I would get perches from Ruff Stuff Specialties.They are 7 or 8" long to help combat axle wrap.
