jimoshel Posted February 24, 2013 Share Posted February 24, 2013 Exactly what is the weakness of the Dana 35? Spider gears? Ring gear? tubes coming loose? Metal flexing, etc. Is there a way it can be overcome or improved? Swap gears with stronger aftermarket? Weld the tubes? Truss it? Drill holes in the assembly for improved air cooling? Don't start on swapping with a Dana44. or AMC20. I'm just curious as to what the weakness is. In reading everything the C clip coming loose or breaking and letting the axle take off seems to be the biggy. :dunno: Link to comment Share on other sites More sharing options...
mnkyboy Posted February 24, 2013 Share Posted February 24, 2013 The biggest issue is the ring and pinion, you can make a D35 as strong or maybe stronger then a stock D44 other then the centersection. I actually beat the crap out of my stock non c clip D35 and it refused to die. Link to comment Share on other sites More sharing options...
dasbulliwagen Posted February 25, 2013 Share Posted February 25, 2013 Lately, whenever Ive seen one on here thats went bad, its the spiders that have grenaded and took out the rest of the internals. And if you get rid of the spiders and install a locker, then you break axles, or if the axle doesnt break, the housing bends. I think C-clips were only in later model 35's, but yeah, they werent any good either. For what it would take to beef up a 35, you could buy and install something else just as good or better. Link to comment Share on other sites More sharing options...
HOrnbrod Posted February 25, 2013 Share Posted February 25, 2013 For me it was axle snaps, two in a year, both on the driver's side. I suppose it was the stroker as both happened at stop lights taking off. It's embarrassing. Never hurt the spiders or ring and pinion. Should be fine and last forever with a 2.5 and stock tires though. One thing about the c-clips is that the axles are simple to change. Link to comment Share on other sites More sharing options...
Bornindesert Posted February 25, 2013 Share Posted February 25, 2013 Are the axles retained when they snap or do they walk out - non C-clip D35 question? Link to comment Share on other sites More sharing options...
HOrnbrod Posted February 26, 2013 Share Posted February 26, 2013 For non C-clip D35s (and D44s) the bearing retaining plate which is T-bolted to the axle housing holds everything in. Link to comment Share on other sites More sharing options...
Geonovast Posted February 26, 2013 Share Posted February 26, 2013 On 2/25/2013 at 10:15 PM, hornbrod said: For me it was axle snaps, two in a year, both on the driver's side. I suppose it was the stroker as both happened at stop lights taking off. It's embarrassing. Never hurt the spiders or ring and pinion. Should be fine and last forever with a 2.5 and stock tires though. One thing about the c-clips is that the axles are simple to change. I've had 3 XJs and 2 MJs with a D35. The only axle I killed was the one behind the only 2.5, with the smallest tires of any of them. I don't know if it's anything I did though, as the carrier bearings went out on it. Link to comment Share on other sites More sharing options...
jimoshel Posted February 26, 2013 Author Share Posted February 26, 2013 Contrary to popular belief, a smaller engine can be harder on the drive train than a larger one. Reason being people revving it harder and slamming the gears when shifting and letting out the clutch than they do with the larger engine. Link to comment Share on other sites More sharing options...
