cherokee_chief Posted January 22, 2013 Share Posted January 22, 2013 ok soo i swapped a full cluster from an xj into my mj (dummy cluster) a while back, everything worked fine just no gas light, just recently i got rid of the mj tank and sunk a xj tank halfway into the bed. i plugged everything in ran the fuel lines start the truck and the fuel gauge is saying full is emtpy and empty is full.... what the hell is going on?! Link to comment Share on other sites More sharing options...
MiNi Beast Posted January 22, 2013 Share Posted January 22, 2013 I have the same issue. Can we just swap the wires being only two and it read right? Seems that would be to easy.... Link to comment Share on other sites More sharing options...
gogmorgo Posted January 22, 2013 Share Posted January 22, 2013 Yup. Wired backwards. Link to comment Share on other sites More sharing options...
HOrnbrod Posted January 22, 2013 Share Posted January 22, 2013 ok soo i swapped a full cluster from an xj into my mj (dummy cluster) a while back, everything worked fine just no gas light, just recently i got rid of the mj tank and sunk a xj tank halfway into the bed. i plugged everything in ran the fuel lines start the truck and the fuel gauge is saying full is emtpy and empty is full.... what the hell is going on?! What model year is the XJ tank & sender you put it the MJ? Link to comment Share on other sites More sharing options...
cherokee_chief Posted January 22, 2013 Author Share Posted January 22, 2013 Its out of a 95 and the cluster is from an 88. It has an new pump in the tank. How could it be wired wrong when theres only 3wires and its a factory plug connection Link to comment Share on other sites More sharing options...
87manche1 Posted January 22, 2013 Share Posted January 22, 2013 I heard newer tanks read in reverse. The sender is resistive check ur old unit with a volt meter that has ohms. And do the same with new and compare Link to comment Share on other sites More sharing options...
HOrnbrod Posted January 22, 2013 Share Posted January 22, 2013 Its out of a 95 and the cluster is from an 88. It has an new pump in the tank. How could it be wired wrong when theres only 3wires and its a factory plug connection Starting in 1991 the variable DC signal to the gas gage changed polarity. Just swapping the signal wires at the gage will not work; all it would is cause the gage to read full when empty and vice-versa. To make the gage work in the right direction you need to swap the output wire on the fuel sender potentiometer from one leg of the pot to the other. I don't even know if that terminal is accessible on the 95 sender, but it should be. You will have to pull the sender and look. Take a pic of the wire connections on the sender if you can. Link to comment Share on other sites More sharing options...
cherokee_chief Posted January 22, 2013 Author Share Posted January 22, 2013 Could i just put an older pump in? Link to comment Share on other sites More sharing options...
HOrnbrod Posted January 22, 2013 Share Posted January 22, 2013 Could i just put an older pump in? Yes, if you can find a 1990 XJ and below fuel sender that fits the 1995 tank. http://comancheclub.com/topic/15047-ho-fuel-sending-unit/#p163162 Link to comment Share on other sites More sharing options...
